Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Let's Talk XT6 Clutches
#1
Posted 09 April 2006 - 10:44 PM
I will be installing a GL D/R into a '93 Loyale and wish to use an XT6 clutch for the added clamping force. I understand I will need the clutch and pressure plate. Will I need the XT6 flywheel or will a S/R flywheel work just fine?
Thanks in advance.
#2
Posted 09 April 2006 - 11:12 PM
#3
Posted 09 April 2006 - 11:17 PM
ea82 fly6 wheel = like 15-20 lbs
#4
Posted 09 April 2006 - 11:23 PM
You will probably not want to use a lighter flywheel for any kind of crawling.
#5
Posted 09 April 2006 - 11:38 PM
Thanks guys.
#6
Posted 10 April 2006 - 12:16 AM
Jeff=crazyxt-6 flywheel = 9lbs
Really the XT-6 fly weights 19 Lbs
XT Turbo fly weights about 26.
#7
Posted 10 April 2006 - 02:02 AM
Jeff=crazy
Beat me to it.
BTW, the XT6 flywheel isn't aluminum, it is cast just like all the other ones. The steps are the same on both flywheels.(EA81 is different) The difference is in the the plate and the discs are the same I believe.
Also, who in the heck said the Impreza clutch would work?
#8
Posted 10 April 2006 - 02:35 AM
It was either me or WJM, or both, as it has the same spline count as the 5MT D/R, the pressure plate is obviously different, as the EJ flywheel doesn't have a step, but the clutch friction material will work, or so a crazy guy in Michigan told me, as he was using it in his T-Wag
#9
Posted 10 April 2006 - 04:58 AM
Holy Crap!!
Is that a magical XT6 flywheel?
Mine weighed in a just over 18 pounds
EA82 (4WD and all turbo) Weighs in around 24 pounds
Hahah.. I suppose I should read the whole thread before posting
#10
Posted 10 April 2006 - 08:29 AM
http://dodgeneon.net...2/v/gl10/album/
#11
Posted 10 April 2006 - 04:19 PM
#12
Posted 10 April 2006 - 06:14 PM
#13
Posted 10 April 2006 - 09:48 PM
Dylan86GL10: you selling all that or putting it in your car?
Just got it all from grossgary so its going into my wagon in the next couple days. In fact Gary supplied the turbo motor too!
#14
Posted 11 April 2006 - 01:16 AM
my bad sirJeff=crazy
lost a few digits in translation
sorry
#15
Posted 11 April 2006 - 06:56 AM
next up is an LSD trade for megasquirt !!!!! ha ha.
that wagon is awesome.
#16
Posted 11 April 2006 - 07:59 PM
I take it the Impreza clutches will not work, Ken? In which case, what is a clutch brand you would recommend for my wagon? I've heard wonderful things from Jamie Thomas about Spec clutches, and it appears they offer a number of applications appropriate for an EA82.
#17
Posted 11 April 2006 - 09:00 PM
Little trick for you next time - don't tighten the clutch plate - leave it loose so the disc can be moved up and down with your finger, then tighten the plate through the starter hole after it's mounted. I've run into a couple of cheap alignment tools that didn't work, but this method always does.
No offense but...
I have heard this before and it is an incredible waste of time. Unneccessary work and time that could be used for other things. The correct alignment tool and 10 minutes is all that is neccessary to install the engine or trans. You can ask anyone who has seen me install an engine how easy it is to do it the right way. I think you have seen me do one as well Rick.
#18
Posted 12 April 2006 - 06:29 AM
agree. 10 minutes you say? that much, i think you're exaggerating! it was so simple the first time i did it i thought for sure i had done something wrong (even posted about it!). so easy, air filters can be trickier to install that the clutch disc!No offense but...
#19
Posted 12 April 2006 - 08:32 AM
Ears perk up, head turns sideways. Lemme get the brown beast running on the turbo motor so I can sell you on the MS.
#20
Posted 12 April 2006 - 08:34 AM
thumbs up!Lemme get the brown beast running on the turbo motor so I can sell you on the MS.
#21
Thats 10 minutes to get the clutch aligned, motor mounts in and the started in and tightened
#22
Posted 12 April 2006 - 10:52 AM
What will NOT work is the whole Imp. clutch. What WILL work is the disk. Look up part numbers on clutch sites and you will find that the same numbers are listed for the EA 4wd and the EJ cars (most) - but usually the really sticky versions are only listed for EJ's. No reason why they can't be used on an EA, but the stock hp doesn't require it!!
#23
Posted 12 April 2006 - 08:40 PM
That's Sort of right, 10 minutes to align the clutch and install it into the car!
Ideally, you have to be smarter than the tools you're using. Even the generic universal alignment tools work well if used correctly.
