problem with headlight circuit
2 replies to this topic
#1 rsb
rsb
    New User
  • PipPip
  • 22 posts
  • redmond
Posted 10 April 2006 - 02:35 PM
Hi,
I was trying to fix the dashlight on my 78 brat... I figured it was just a bulb so I pulled one out of my spare instrament cluster, but that didnt help... so I cheked the headlight switch fuse and it was burning hot after only a short while... (have a nice fuse shaped burn on my finger)... everything works except the dash light, but the fuse gets dangerously hot. Has anyone else had this problem? Any idea what is wrong with it?
#2 SUBARU3
SUBARU3
    Moderator
  • Moderator
  • 2,832 posts
  • Dallas, Ft. Worth, Texas
Posted 11 April 2006 - 11:36 AM
That hot fuse for the headlights was actually a recall on most Gen 1s. The dealership bypassed the fuse block and installed a heavy duty harness and separate fuse.
The resistance in the stock fuse block is too great and it heats up. In many cases melting the plastic plug on the back of the fuses. It could cause the lights to fail and an accident to occur.
Separate it and wire in a heavy duty harness.
Todd
#3 rsb
rsb
    New User
  • PipPip
  • 22 posts
  • redmond
Posted 12 April 2006 - 07:12 PM
Thanks for the heads up! I noticed on my parts car that that part of the fuse block was missing that part and the plug was burnt, so I had a feeling it was probably a common thing. Any suggestions what gauge wire to run?
Thanks!
Brian
