*edit* Are these coilover converters ebay enough??
5 replies to this topic
#1 eddygordouk
eddygordouk
    USMB is life!
  • 245 posts
  • Sacramento
Posted 10 April 2006 - 11:59 PM
*edit* found these on ebay and wanted to pick up a set, that is, if they can fit on stock RX struts and/or kyb gr-2s. are they or do i have the wrong thing...plus what would be a recommended pring height? since i would go for a little higher spring rate ( i would like around 210~) what would be a ratio for the front and rear? thhanks for any help *edit*
Can I/should I convert RX struts to coilover with a ground control convertter setup? it sounds like it would be decent and my struts are dead yet, might as well make em :banana: but what does everyone think? Or should i jus do that to some gr2s instead? since u can get the small xt fronts :confused:. I really want the dampening abilities of the RX struts but with a higherr spring rate, i dont really care about hight right now and would only lower alittle if i wanted to...
#2 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 11 April 2006 - 09:52 AM
Not specifically familiar with the ground control setup . Is it any different than any of the other aftermarket coilover sets?
Posted Image
#3 eddygordouk
eddygordouk
    USMB is life!
  • 245 posts
  • Sacramento
Posted 11 April 2006 - 04:18 PM
its the same, sad thing is is that the search on ebay for the setup returned nothing. It seems as though I cant find them anymore and all it does is return legit ground controls :confused: I would like to run a more decent suspension setup and i will keep my 13"s till i move on to my lug swap later on down the road, anyone have some ideas?
#4 eddygordouk
eddygordouk
    USMB is life!
  • 245 posts
  • Sacramento
Posted 12 April 2006 - 09:55 PM
no noe has any recommendations?
#5 970subaru
970subaru
    Subaru Fanatic!
  • 460 posts
  • sleazattle wa
Posted 14 April 2006 - 05:35 PM
"impreza coilovers"
http://cgi.ebay.com/...1QQcmdZViewItem
#6 970subaru
970subaru
    Subaru Fanatic!
  • 460 posts
  • sleazattle wa
Posted 14 April 2006 - 05:39 PM
"impreza coilovers"
look at some circle track racing suppliers too, they have lots of good options for assembling a coilover kit though the price will be similar to groudn control.
