XDGT03 Posted April 17, 2006 Share Posted April 17, 2006 Can synthetic oils and lubes be used in the 73 models for motors, brakes, trans gear lube, etc... Do the manual trans' use soft metal in them for say the synchros? Can you tell me the recommended gear lube weight and rating (gl-3; gl-4; etc...)? Brake fluid says DOT3. Is there any harm in using higher temp and/or synthetics? Thanx for any help you can provide. Quote Link to comment Share on other sites More sharing options...
