Oil capacity and spark plug socket of EJ18
4 replies to this topic
#1 bowjam
bowjam
    USMB Regular
  • PipPipPip
  • 50 posts
  • Martinsville
Posted 24 April 2006 - 05:48 AM
95 Impreza 5 sp. coupe 1.8L
Would you know how much oil it takes for a EJ18 ? I put in 4 qts and it looks ok on the oil stick. I know some of the subie engines take >4qts.
What kind of socket is used to replace the spark plugs? I've got four 13/16 sockets and none of them will fit in the plug hole. Boy was I surprised..
I also have a 98 legacy with 2.2L and an 01 Legacy with a 2.5L all three engines take the same oil filter.. That's amazing to me. Subaru has got their act together in more than one way..
Thank you
#2 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,953 posts
  • Denver, Colorado
Posted 24 April 2006 - 10:50 PM
Its a 5/8 spark plug socket. Hardware store should have a socket for you. No need for a wobble on the socket if you ask me. 4.2-4.5 quarts with filter change.
#3 bowjam
bowjam
    USMB Regular
  • PipPipPip
  • 50 posts
  • Martinsville
Posted 24 April 2006 - 11:08 PM
What type of plug is recommended for the 1.8 L ?
Ok, it requires the same amount of oil as the 2.2..
I think I have a 5/8 deep socket.. Just had not idea it
wasn't a standard size plug. I have a box of BKR6E-11.
Assumed they were the replacement plug.
Any Idea where I can download a Owner manual ?
The "My Subaru" site only goes back to 1997..
Thanks for the info..
#4 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 24 April 2006 - 11:42 PM
you'll really want a 5/8 sparkplug socket with the rubber ring or magnet built in, and not just a deep socket. The plugs sit a little ways down in the hole and pulling it out will not be easy without a sparkplug socket. Also make sure the compression washer comes out with it. The correct plug is BKR6E-11.
#5 bowjam
bowjam
    USMB Regular
  • PipPipPip
  • 50 posts
  • Martinsville
Posted 25 April 2006 - 01:28 AM
I really feel dumb now.. I had just replaced plugs in a Toyota truck prior to the Impreza and didn't remember the Subie having the smaller 5/8". I just looked at the BkR6E-11 and realized my brain was out to lunch.
Sorry for the CRS. I will try to do better..
Thanks for the wake up call..
