Fuel pump pressure ea82 carb
2 replies to this topic
#1 mcs
mcs
    New User
  • PipPip
  • 20 posts
  • Sydney
Posted 30 April 2006 - 08:15 PM
fuel pump pressure issue on EA82, carb, auto choke, manual 4x4 (1987)
I apologise for such a lame question but I replaced my fuel pump a while ago ( previous one dripped fuel ) but I have just noticed that when I'm on tick over my manifold vacume isn't constant and my exhaust smells a little rich. I believe that my needle valve is being over powered by the new fuel pump but I can't find a reference to say what the PSI should be.
I bought a generic pump designed for cab engines which didn't specify PSI on it but I'm going to connect a gauge to it tonight and find out.
If this is the case does anyone know of a place I can get a simple fuel restrictor, no bells or whistles, or is there anything I'm missing. I don't want to buy another pump unless I have too.
Incase anyone is thinking, I had replaced the fuel filter a little while ago which is probably what caused the original fuel pump to malfunction in the first place.
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,376 posts
  • Portland
Posted 30 April 2006 - 08:16 PM
Should be around 2 - 3 PSI.
You can get a pressure reducer from any good parts store usually. The performance places that sell lots of holley and edelbrock stuff usually have them.
#3 mcs
mcs
    New User
  • PipPip
  • 20 posts
  • Sydney
Posted 30 April 2006 - 10:11 PM
Thanks matey, thats obviously my problem then as new pump says 7 psi on the side. Strangely enough new 1-3 psi pump is cheaper than new damper. Ohh well, serves me right for not double checking before fitting.
At least it ends with a cheap solution.
Thanks again:banana:
