kayakertom Posted May 3, 2006 Share Posted May 3, 2006 Am ready to start my conversion. The white '87 gl 3-door ea82 has only 134K on it. It had a HG problem along with stripped plug threads and apple cored governor gear. Replaced one head and put in a replacement governor gear, but after just 8 miles, it shows coring again. Engine runs great. Bought a bare d/r transmission - supposedly a jdm one with less than 60K miles through it. Found an '87 gl wagon (264K on odometer) also with a d/r transmission with interior trim that matches the 3-door. Have pulled the motor already and seperated the pressure plate, flywheel and bellhousing. Plan to pull the 3-door motor and then the auto trans. Have pulled ea82 motors 6x now, but not from an automatic - any advice? The jdm trans has apparently been lying around for the past 4 years without any oil, should I replace any seals? Have an excellent - lower mileage pedal assembly ready to go in the 3-door (thanks Ed). Anything else to worry about? PS: There is usually good beer here. Quote Link to comment Share on other sites More sharing options...
Dylan86GL10 Posted May 3, 2006 Share Posted May 3, 2006 The only thing I faced pulling the 3AT was a hidden ground wire on top of the trans. Couldn't figure out what was caught and ended up breaking it. http://dodgeneon.net/gallery2/v/gl10/album/ Quote Link to comment Share on other sites More sharing options...
