'87 RX Project Update (56K Beware)
37 replies to this topic
#1 Subarutex
Subarutex
    Oldschool Show Queen
  • Moderator
  • 2,551 posts
  • Mountlake Terrace
Posted 25 October 2003 - 10:58 PM
Well, i haven't posted about the car in awhile. Thought I'd show off what I've been up to the last couple of months. First off, I'd like to thank all the people that have helped me out with my endeavors. Andy, Corky, you guys rock!
Just today, I finished off the car. I'll show before, then afters...then i'll explain whats going on!
Engine Before:
Posted Image
Engine After:
Posted Image
As you can see, i've swapped in the spider intake. I also put in an xt6 flywheel, clutch, and pressure plate. And remade the cold air intake, that I made an aluminum divider for.
Car Before:
Posted Image
Car After:
Posted Image
Posted Image
Now I'm sporting an XT6 5 lug swap. In front, i have 2.5rs struts, with the stock RX springs in them. XT6 front spindles, brakes, axles, lower control arms, and sway bar. In the rear, i just have the XT6 hubs, rotors, and backing plates.
The wheels are 18" Enkei CDR-9's. I've only rubbed once. I think the wheels are a bit too big, and I'll probally get some 16's or 17's for it instead.
Current mod list -
Engine: 13psi with boost controller, WRX intercooler w/BOV, spider intake, custom CAI, XT6 flywheel, clutch, and pressure plate
Suspension: 5 lug swap, XT6 sway bar, RS struts
Electronics: Apexi S-AFC (fuel control computer, sorta), Apexi Turbo timer w/ A/F ratio gauge
Other: Hood Scoop, 18" rims, Boost gauge
#2 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 26 October 2003 - 12:17 AM
That looks great Tex. I would really like to see how you did the intake, debating wether to keep or sell the one I have. Seeing how Im going to be getting a RX as soon as my coupe sells.
Rob
#3 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 26 October 2003 - 01:27 AM
Looking great tex. I have to admit tho, those 18's do look alittle too big. I'd prolly go with 16's to give you more wheel travel.
-Brian
#4 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 26 October 2003 - 02:34 AM
that engine looks GOOD. 'specially with an IC :D
and you're welcome. that there throttle position sensor came from my soon-to-be-installed engine which used to be tyrel neufeld's which used to be rguyver's. i love how parts and things get reused and recirculated on this board..
#5 89urabus
89urabus
    New User
  • PipPip
  • 22 posts
  • albany,or
Posted 26 October 2003 - 02:37 AM
seeing that rx makes really want one for myself as soon as I can afford one and find one in good shape I,m also thinking about getting the body kit off one for my gl if it will fit.
#6 carfreak85
carfreak85
    Temple of Fuji
  • 5,213 posts
  • Cascadia
Posted 26 October 2003 - 03:36 AM
tex that looks friggin' sick!!! i like the 18s, though from an engeneering standpoint id go with whatever was lightest, but still sick!!! btw whats the plan for those old crappy enkeis?:D
#7 Subarutex
Subarutex
  • Moderator
  • 2,551 posts
  • Mountlake Terrace
Posted 26 October 2003 - 04:03 AM
I'll be putting them up for sale here soon. I need to clean them, and take some good pics and stuff.
#8 Myxalplyx
Myxalplyx
    Old Wise and Dumb
  • 1,838 posts
  • New Castle
Posted 26 October 2003 - 06:16 AM
Hello Subarutex,
First off, I just wanted to say that your ride looks VERY nice. I really like how you hooked up the intercooler with the hood scoop. I just have a few questions if you don't mind.
1) What is your Sensor Calc and Sensor Number setting for your Apexi SAFC on your EJ18 setup?,
2) What kind of tubing/piping are you using to connect your Maf sensor to your turbo, turbo to intercooler and your intercooler to your throttle body? Where can I get this tubing/piping?,
3) Your cold air intake setup looks sweet. How did you go about hooking the air filter to the Maf sensor? This part seems more difficult than hooking the Maf sensor to the rubber-like piping since the air filter to MAF seems to require bolting up.
4) Will an xt6 flywheel, clutch, and pressure plate be able to fit a 1985 RX?
Sorry for all the questions but I'm trying to learn something here. Really nice looking setup you have. Looks promising! I'm dying to know what kind of trap speed your car will run in the 1/4 mile but most people here don't go to the strip so I don't ask anymore. *hint, hint*
If you don't want to give away some of the information, that's understandable. I am looking through your website now (wasn't aware of it before). I can see how you re-modified your intake from what it used to be to what it is now. Nice!
Does anyone know what is the widest tire you can use on stock rims. I have some 175/70-13's with Goodyear Decathalon tires on it that I'd like to make wider in the future. Thanks!
#9 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 26 October 2003 - 06:58 AM
Myxalplyx: Ive got 205/60's on my stock 5 inch wide rims. I think I might coiuld suqeeze 215/60s on there...but it'd be tuff. Even so, the tire profile would be more rounded on the outer edges, more so that the 205 already is. But then again, I am running about 43 psi is each tire.
And Subarutex: I have the same Q's!
#10 XSNRG
XSNRG
    Elite Master of the Subaru
  • 3,657 posts
  • Olympia
Posted 26 October 2003 - 09:16 AM
NICE!:headbang:
#11 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 26 October 2003 - 09:51 AM
Yes sir, saw it in person on Saturday. Looks very good.
#12 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,271 posts
  • Everett, WA, USA
Posted 26 October 2003 - 11:48 AM
So i thought that i wanted an RX, only wanted because they're not the off roader that the hatches, wagons and, brats are, but after seeing that i can only say that i need one now. very sharp.
#13 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 26 October 2003 - 12:11 PM
Looks good Tex, why don't you come over and we'll slap some 16's on there to see how that looks.
Hey Freak, I thought you were buying a set of wheels from Ed Rachner??
#14 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 26 October 2003 - 12:17 PM
I think I can answer some of these questions, but first, what EJ18 setup??? He used a spider intake off of an XT4 (EA82). Question 2, he made a lot of trips to the hardware store PVC section. He'll have to answer #3. #4, yes.
#15 LegacyT
LegacyT
    USMB Regular
  • PipPipPip
  • 110 posts
  • Ottawa, Canada
Posted 26 October 2003 - 12:29 PM
Awesome Car:banana: Just one thing, the wheels are a little big, 17's would look better IMO. Cool car none the less.
Mark,
#16 bushbasher
bushbasher
    exhaust fume addict
  • 1,707 posts
  • Sooke B.C. Canada
I agree that the you should go down to a 16, and get a bit more sidewall, keep it low profile, but just a bit more meat there. Also maybe go for some wheels with thicker spokes. I'm sounding kind of critical but really I too agree that you've done a beautiful job.
#17 Myxalplyx
Myxalplyx
    Old Wise and Dumb
  • 1,838 posts
  • New Castle
Posted 26 October 2003 - 12:41 PM
Thanks for answering question number 2. Question one is in reference to a 1985 RX that I plan on purchasing BUT I wanted to know what his current Sensor Calc and Sensor Number setting are on his Apexi SAFC. These settings are what mostly prevented me from using the Apexi SAFC on my XT6 and I have sense taken it off (then it got stolen out of my Outback Sport :madder: ). It's good that someone installed it on their RX as a guinea pig to make things easier for the rest of us seeking this route I hope.
There are a couple other settings like the type of Maf sensor but different RX's have different types of Mafs I thought I read here.
Another reason I was thinking of putting the SAFC on the RX is to raise the fuel cut limit after installing higher flowing injectors. This is what I read off of an SAFC tuning site (Road Race Engineering)......
"Fuel cut is caused by the ECU seeing a large airflow value from the MAF which works out to roughly 100% duty cycle on the stock injectors. If you install 550cc injectors which are 18% bigger than the stock injectors, then adjust the AFC to compensate for the larger injectors, you won't hit fuel cut until you
make up that 18% airflow buffer. *These sizes don't apply to OUR cars but the idea remains the same*........."
I know a lot of you know this stuff already but some of us don't.
When u said he is using the spider intake off of the XT4, was that in reference to his MAF sensor hooking up to the air filter, the piping going from the intercooler to the throttle body, the intake manifold itself or something else? Just a little confused!
#18 carfreak85
carfreak85
    Temple of Fuji
  • 5,213 posts
  • Cascadia
Posted 26 October 2003 - 02:54 PM
Hey Corky, I am buying wheels from Ed, but Im interested in these too if the price isnt too high. need street tires and slicks for racing!!!
#19 SuperRallyRoo
SuperRallyRoo
    Defundit.com
  • 1,430 posts
  • Tacoma, Wa.
Posted 26 October 2003 - 03:36 PM
U do mean for auto cross and not illegal street racing right.:rolleyes:
#20 carfreak85
carfreak85
    Temple of Fuji
  • 5,213 posts
  • Cascadia
Posted 26 October 2003 - 03:57 PM
yeah for the most part! no but i want the lightest alloys possible for autox and some nice big pugs for the street.
#21 Subarutex
Subarutex
  • Moderator
  • 2,551 posts
  • Mountlake Terrace
Posted 26 October 2003 - 04:10 PM
I'm not too sure what my sensor calc and sensor number settings are, i can certainly check though.
I noticed when i was running 10psi of boost, that i wasn't hitting fuel cut hardly ever (with the S-AFC) Now I am running 13psi of boost, and I seem to be hitting it all the time. I've adjusted the SAFC a little bit, but i think the answer really lies in this: DIY FCD
I'm currently about half way through wiring this up on a perf board. Hopefully in a month or so I'll get it installed and tested.
The tubing is all a combination of Lowes (hardware store) and schucks. Same goes for the piece that connects the air filter to the MAF, or so the previous owner MikeW told me, he's the one that did the original CAI setup, i just reused that piece.
The old enkei's are far from crappy. I've never seen another set like them. Most of the old people here haven't either. These are rare wheels. There is a bit of curb rash. How much are you looking at spending Freak?
#22 carfreak85
carfreak85
    Temple of Fuji
  • 5,213 posts
  • Cascadia
Posted 26 October 2003 - 04:20 PM
i was joking about the crappy enkeis, just to make them sound bad to everyone else!!!:drunk: i was hoping to spend as little as possible, not sure how much youre looking for, but let me know in a PM and well talk.
#23 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 26 October 2003 - 04:36 PM
I was talking about the manifold. When you (Myaxlphyx) said, "...on your EJ18 setup?", I thought you were talking about the intake. I couldn't figure where the reference to an EJ18 was coming from.
Hey Freak, Ed is moving soon, and I'm sure he'd like to move on less set of wheels, so you'd better get up there now.
#24 Mike W
Mike W
  • 706 posts
  • Seattle
Posted 26 October 2003 - 04:56 PM
Yeah Tex, the RX is lookin' real good man. I'm really liking what you've done with it and I'm very glad you got the car. That's partly because I couldn't afford the speeding tickets:-)
Regarding question #2, about the MAF to airfilter adapter... It came from Home Depot and it was a row or two over from the PVC stuff in the drain pipe section. The adapter flange was a storm drain I think like you'd use in front of a residential garage door. I believe there was a green plastic grate that snapped on but I might be wrong about that. Anyhow it fit and flowed perfect with minimal effort.
#25 carfreak85
carfreak85
    Temple of Fuji
  • 5,213 posts
  • Cascadia
Posted 26 October 2003 - 06:40 PM
I PMed Ed, so i should know more shortly. thanks for the heads up Corky!!!
