JonOfScio Posted October 26, 2003 Share Posted October 26, 2003 Are turbo valve springs any stiffer than carbureted ones? I can get new ones from Shucks, and there's different weights... one of them is lighter weight than the other (brand) and there's also Manual and Automatic springs... and then of course I can grab a set of hardened springs from Ramengines for $45 a whole set. Reccomendations? Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted October 26, 2003 Share Posted October 26, 2003 If you're going to be running a custom cam get the springs from ram, without them you might have vavle float Quote Link to comment Share on other sites More sharing options...
JonOfScio Posted October 27, 2003 Author Share Posted October 27, 2003 I'm aware of valve float, and I was just interested in differences between springs. Most likely, if I do decide to get better valves (most likely won't change cam) I will go with the Ram Engines ones. Quote Link to comment Share on other sites More sharing options...
