6 stud hub conversion - need help with drill bit size
2 replies to this topic
#1 Phizinza
Phizinza
    Yip yip
  • 3,937 posts
  • South Australia
Posted 06 May 2006 - 01:03 AM
Ok, so I am doing the 6 lug conversion. I only have (had, I just broke it) 13mm drill bit. I read that I need a 9/16th's bit, and somewhere else I read 14mm. Seems the 9/16th's bit is about 14.29mm i figure this is a big difference. So, tell me, what size do I need!??!
BTW, I have a drill press and all, I've got 13mm holes in one of the hubs and they are PERFECTLY aligned (good eye sight I guess). I was feeling good about it all, until I found out my local hardware store only sells upto 13mm bits.. Then I broke mine.. And even more has gone wrong today. So, before I continue to stuff everything up I'll just get you to conferm which size I need... Thanks!
#2 SOOBOUTLAW
SOOBOUTLAW
    Junkyard Junkie
  • 536 posts
  • EVERETT
Posted 08 May 2006 - 07:56 PM
Use a 1/2" bit, almost perfect if not exactly for 13mm.
Not sure of lug stud size though...
#3 Phizinza
Phizinza
    Yip yip
  • 3,937 posts
  • South Australia
Posted 09 May 2006 - 07:48 AM
I saw on a packet of wheel studs it said drill a hole 0.25mm smaller then the splines. The splines are 14.28mm wide. So I am guessing a 14mm drill bit should do good.
BTW, as I said before, I am drilling the hubs, not the wheels. So 13mm just isn't going to do it.
