yellowing cloudy headlight lenses
18 replies to this topic
#1 bgambino
bgambino
    Subaru Nut
  • 710 posts
  • new york
Posted 10 May 2006 - 06:58 AM
96 OB
can anything be done about these to clean them?
Glass lenses have their advantages....
#2 BL99
BL99
    New User
  • Pip
  • 2 posts
  • crisfield
Posted 10 May 2006 - 07:13 AM
I used a mild fiberglass polish on our's, worked good, not origional but much better.
#3 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,781 posts
  • Texas
Posted 10 May 2006 - 07:53 AM
96 OB
Try a search on this subject.
Generally, 2-3-4 finer stages of wet sanding with a good wax or maybe a clearcoat spray. There are plastic polish kits too IIRC for this.
(CAFE standards means getting the weight down - plastic wins over glass for weight. Some European market cars had (still have?) glass while we were getting plastic)
Carl
#4 rlsimpso
rlsimpso
    USMB Regular
  • PipPipPip
  • 121 posts
  • Ferndale
Posted 10 May 2006 - 04:02 PM
I had the same problem on my 98 Legacy GT. I just cleaned the headlights and fog lights(what a joke) with the two part 3M plastic cleaner and polish. This stuff works very well. It took about 5 minutes a light and they looks like new. It also helps smooth out small pits from rock chips too. It also works great on CDs.
Any good auto parts store should carry it.
http://www.autogeek....plascleanp.html
I also have had success with Mother's mag and aluminum polish. A friend who is a BMW mechanic recommended it. It works, but takes much more effort then the 3M cleaner.
Rob
#5 northguy
northguy
    O.C.A.L. Life Member
  • 4,352 posts
  • Chugiak, AK
Posted 10 May 2006 - 09:57 PM
There were a couple of good threads on this last Fall. Do a search. One method suggested was brake fluid - but it absolutely had to be a fresh bottle of Subaru brake fluid. Look it up, I'm not fooling.
#6 JPX
JPX
    Eat, Live, Breath Subaru
  • 316 posts
  • San Jose
Posted 10 May 2006 - 10:17 PM
Try reading up on this thread->http://www.ultimates...ead.php?t=57486
Posted Image
#7 LosDiosDeVerde86
LosDiosDeVerde86
    1000+ Super USER!
  • 1,358 posts
  • Columbus
Posted 11 May 2006 - 08:36 AM
96 OB
wow, this has been a hot topic lately
#8 JPX
JPX
  • 316 posts
  • San Jose
Posted 11 May 2006 - 10:01 AM
I guess with the sun coming out more often, people have had a chance to wash off the winter crud. That's when they really see how bad the headlights can get - especially compared to the crystal clear stuff on brand new cars (like the new Outbacks.....arf).
#9 blitz
blitz
    Banned
  • Banned
  • 1,091 posts
  • Warren, Michigan
Posted 11 May 2006 - 10:53 AM
Several times a year I'll "wax" the lenses with whatever car paint-care product I happen to have laying around.
I've been doing it since the car's been new and aside from the requisite stone pits, the lenses look as clear as ever.
Apparently the easiest way to "remove" the yellow is to not let it happen.
#10 dj3stripes
dj3stripes
    USMB Regular
  • PipPipPip
  • 109 posts
  • Omaha
Posted 01 June 2006 - 04:05 PM
total newb here, and first post as well. first off i know very little about cars and mobile wiring/engines, so appologies in advance.
how does this yellowing occur in the first place? i just got a great deal on a 95 legacy LS, and only one headlight is clouded with the yellow haze i've been reading about.
-Thanks.
#11 rlsimpso
rlsimpso
    USMB Regular
  • PipPipPip
  • 121 posts
  • Ferndale
Posted 01 June 2006 - 05:09 PM
I believe it has to do with the UV resistance of the plastic used to make the lens. Most older cars with plastic headlights seems to get yellow like that.
I found out brake fluid turns them white:mad:
You should see some of the crappy old (insert big three auto of choice here) driving around detroit. I they looking like yellow foglights in the dark. It is a good thing there is not vehicle inspection here, or those people would be SOL
Rob
#12 unobtainium
unobtainium
    USMB Regular
  • PipPipPip
  • 44 posts
  • San Narciso, CA
Posted 01 June 2006 - 06:54 PM
Toothpaste. Just take some Colgate, put it on a rag, and buff the lens by hand. It doesn't take that long, you can use plenty of pressure and you are not going to go too far, since the toothpaste is a very fine abrasive. This works on the clear plastic dashboard cover, too, but you cannot push as hard.
Meguiar's NXT is fine for treating the lens after you wash the toothpaste off. It seems to help delay the onset of yellowing.
#13 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 01 June 2006 - 08:04 PM
There is also polish available at autoparts stores, the two part system works best.
nipper
#14 subeman90
subeman90
    Soobologist
  • Moderator
  • 2,805 posts
  • Akron PA
Posted 01 June 2006 - 08:54 PM
I got something at autozone over the weekend and did the lights on my legacy and my moms legacy and it was freakin awesome. It comes in a kit and you use a drill to buff them with these special pads. I did a friends 98 Grand Cherokee (you know how they get really bad) and in a matter of minutes they were almost like factory new.
oh and what I got at AZ was only $11
#15 mattocs
mattocs
    Subaru Legacy Lover
  • 1,312 posts
  • Pittsburgh
Posted 01 June 2006 - 08:57 PM
It seems on my Outback that the yellowing is on the inside of the lens.
I am going to try the toothpaste method tomorrow.
#16 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 01 June 2006 - 09:03 PM
google yellowed headlights, there lots of information out there, as we are not alone.
nipper
#17 rlsimpso
rlsimpso
    USMB Regular
  • PipPipPip
  • 121 posts
  • Ferndale
Posted 02 June 2006 - 10:19 AM
This kinda makes me long for my 87 GL 1800 with a 2 barrel and dual range.
That had glass headlights.
#18 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 02 June 2006 - 10:40 AM
i miss the dual range, i dont miss the 2 bbl with its miles of vacume lines
nipper
#19 andrew.anderson
andrew.anderson
    New User
  • PipPip
  • 21 posts
  • Germany
Posted 17 June 2006 - 03:57 AM
Those HL look good.
I am going to fix the HL on our 99 Legacy SUS when I redeploy.
This looks like a nice relaxing project to sit on the back porch and complete.
