Guest sonnyny Posted August 12, 2003 Share Posted August 12, 2003 I'm experiencing an idling problem with my 96' 2.5 GT 85k miles at start ups only and only when the car has been sitting and completely cool. Usually happens in the morning and not all the time. It idles correctly at 1st for about 5 seconds, then sputters for 5 to 10 seconds, then revs up to about 3,000 rpm, and then levels off to a correct idle speed. I just purchased the car last month and the problem has come and gone. I recently replaced the spark plugs, air filter, and fuel filter which seemed to cure the problem but it just happened again. The car runs fantastic otherwise. Anybody have an idea ? Quote Link to comment Share on other sites More sharing options...
Guest Legacy777 Posted August 13, 2003 Share Posted August 13, 2003 I'd try running some potent fuel injector cleaner through, may even want to run it on a half tank of gas. Other thought is idle air control valve sticking. Quote Link to comment Share on other sites More sharing options...
Guest remarcable Posted August 14, 2003 Share Posted August 14, 2003 All the hoses that connect to the airbox (where the air filter is) tight and secure? Airbox back together all the way? PCV valve generates suction when you put your finger on it and CLICKS when you remove the finger? Quote Link to comment Share on other sites More sharing options...
