Mikldom Posted October 28, 2003 Share Posted October 28, 2003 I have a 1988 Justy 4wd 5 speed. Has anybody put a cruise control on something like that? can the universal jobbies you can buy at peppunks work? Thanks... let me know.. want to not get a ticket, and set the cruise at 8 miles over on trips and not risk it. Mike mikldom@yahoo.com Quote Link to comment Share on other sites More sharing options...
EmmCeeBee Posted October 28, 2003 Share Posted October 28, 2003 I have an after-market cruise control for my '88 GL 5-speed. I haven't installed it yet, but I've read through the manual. I can't imagine you'll have any trouble with your Justy. One good thing about the kit, after reading the directions: For a manual transmission, you don't need a vehicle speed sensor (VSS). This would be an ECU signal for 1992+, or a couple of magnets you'd attach to a drive shaft. But that's only for an auto transmission. For manual, you only need to tap into an ignition coil lead. This makes sense, since for a manual clutch the engine and vehicle speed are 1:1. I have an Audiovox kit, I'm sure the others are similar. You just tap into a vacuum line, attach a cable to the accelerator linkage (a dozen ways to do this with the kit), mount the switch, and you're done. Theres a bunch of dip switches you have to set, according to whether you're using VSS, auto/manual, etc. One wire taps into the brake light switch; there's no sensor for the clutch pedal 'cuz apparently it cuts out when it senses momentary revving of the engine (this is from the directions; I wouldn't use this method myself). But like I said, I haven't installed it yet. It's still sitting on the garage workbench.... -- Mark Quote Link to comment Share on other sites More sharing options...
EmmCeeBee Posted October 29, 2003 Share Posted October 29, 2003 A side note.... When I was cleaning out my Dad's stuff from the garage a few years ago, I came across what must have been the first "cruise control contraption" made. It was from the early 1950s, so it was in a cool box right from the Burma Shave era. It was a fancy articulated steel gizmo that you placed on the accelerator pedal, with a grip at ankle level that you could adjust to put varying pressure on the accelarator. Plus a linkage resting on the brake pedal which somehow disengaged it in panic mode, I guess. He never did install it, I wonder why??? I shoulda saved that thing, dangit. What I'm gettin' at is that you could always go the broomstick route. If it was good enough for 1950, it's good enough for a Brat -- Mark Quote Link to comment Share on other sites More sharing options...
