rear coilover issue - 84 gl
6 replies to this topic
#1 DualCarb'84
DualCarb'84
    New User
  • PipPip
  • 23 posts
  • Bellevue
Posted 01 June 2006 - 10:39 AM
hey guys, i have a couple questions. I have an 84 gl wagon with a 4 inch lift, that has the disc brake conversion, and a coilover rear suspension, with the torsion bar disconnected/broken. the problem i am having is that when i really get into a trail, or have it loaded, the tires (205/75/14) rub on the side of the coilovers. they are mounted as close to the body as possible, and are in pretty sad shape. I know that if i had a stiffer setup, the problem would be solved, any ideas of a small diameter coilover that would fit/work? Should i attempt putting a new torsion bar on instead? Thanks!:headbang:
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,925 posts
  • Portland
Posted 01 June 2006 - 11:11 AM
Use a wider offset rim - like a Chevy 15x6. I have no rubbing issues with the rear coils (EA82 adjustable, 215/75r15) on my 84 wagon.
#3 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 01 June 2006 - 11:14 AM
where all do you have lift blocks in the rear then?
what kind of mounting bracket do you have for the coil-overs?
I did it like this on a stock brat, and didn't have any rubbing issues....
http://www.ultimates...rear/strut.html
you may just need to get wheel with less backspacing...
#4 DualCarb'84
DualCarb'84
    New User
  • PipPip
  • 23 posts
  • Bellevue
Posted 01 June 2006 - 11:18 AM
i am currently using some 4 bolt pug steelies, if i had another 1/4 inch spacing everything would be fine, i agree, more offset would be better, ya think 15 inch pug alloys would give me the proper clearance, or should i investigate spacers? Ideally the rims you have would be better, but id like to work with what ive got if ya know what i mean.:headbang:
#5 DualCarb'84
DualCarb'84
    New User
  • PipPip
  • 23 posts
  • Bellevue
Posted 01 June 2006 - 11:21 AM
the brackets i am using are 1.5 inch angle iron, attached to the inner wheel well, i already had to beat the snot out of the well to get them as close to the body as i could, avoiding tire rub.
#6 carfreak85
carfreak85
    Temple of Fuji
  • 5,297 posts
  • Cascadia
Posted 01 June 2006 - 02:01 PM
I hear the front springs off of an 88 honda accord are stiffer and will give you a little more lift if installed in the rear.
#7 DualCarb'84
DualCarb'84
    New User
  • PipPip
  • 23 posts
  • Bellevue
Posted 02 June 2006 - 05:54 AM
Thanks for the ideas, i will definately look into the honda springs.
