I've already made great use of these forums by fixing my clock (5 minutes soldering instead of buying a $64 part!).
My "center upper panel box" (i.e., the little center dash compartment) had a broken hinge. I opened it up and was able to repair what seems to be a shoddily-designed $110 part that I'm sure has failed for other folks. My repair is holding so I thought I should pass on the info. This is what we're talking about:
http://www.subarupar...ts/IMG_1285.JPG
Basically the screws of the lid hinge stripped out (and crakced open) their mounting holes on the backside of the bin. To repair, I cleaned and sanded the plastic, then applied $3 of QuikPlastik (plastic epoxy) in a heaping mound over each mount, and gingerly screwed the hinge plate back on while the epoxy was still soft (see photo).
I will post back if this solution doesn't stand the test of time...
