Gen 1 4WD leaking shifter shaft
7 replies to this topic
#1 SUBARU3
SUBARU3
    Moderator
  • Moderator
  • 2,842 posts
  • Dallas, Ft. Worth, Texas
Posted 06 June 2006 - 08:07 PM
Ok....what is the solution for the leaky 4WD/4 speed shifter shaft on Gen 1s??
I park facing downhill to limit the leak. My transmission is fine except for this leak.
Does the case need to be split to fix this? Is there actually a seal there??
Opinions? It seems like a common issue.
Todd
#2 moosens
moosens
    Vintage Subathusiast
  • 1,968 posts
  • Bridgeport CT
Posted 07 June 2006 - 07:13 PM
I'm looking at my FPM and from what I can see there's a seal on that lateral shaft,"rail 3" (shifter fork).Looks like the seal sets into the case from the rear side of the boxy rise in the case.There's a squarish flat cover on the topside held down by 4 Philips screws.
Seal p/n I'm talking about is/was 8067 12050 for 4WD wagon and Brat only.
Rock 'n roll my brother!:-p
#3 SUBARU3
SUBARU3
    Moderator
  • Moderator
  • 2,842 posts
Posted 09 June 2006 - 02:06 PM
So this can be replaced without splitting the case? Through the top access plate? I assume the trans would need to be removed though.
Todd
#4 moosens
moosens
  • 1,968 posts
  • Bridgeport CT
Posted 09 June 2006 - 06:37 PM
The exploded view shows it setting in from the rear,outside.
BUT,you'll have to pop the lid mentioned above and remove the shifter rail by means of first removing the shifter fork.....from looking at the drawing.
Shifter fork is retained by a 5 x 22 straight pin.Four Philips screws and a tiny punch and hammer,then the seal is yours for the picking.
Todd,if you score that seal,can you please snag one for me too?
Thanks!
Seal size -12 x 22 x 5
Talk to you soon.
#5 danrenfroe2016
danrenfroe2016
    USMB is life!
  • 225 posts
  • Dallas, Texas
Posted 20 June 2013 - 08:39 AM
Todd
Todd,
Did this ever get resolved? And did you do it your self? Mine is leaking bad too, Have to leave tranny like half full to not have it leak like crazy.
-Daniel
#6 moosens
moosens
  • 1,968 posts
  • Bridgeport CT
Posted 22 June 2013 - 04:10 AM
Jesse , I know you see this thread ..... LOL
Don't forget that seal these guys are talking about. ;)
#7 danrenfroe2016
danrenfroe2016
    USMB is life!
  • 225 posts
  • Dallas, Texas
Posted 23 June 2013 - 04:02 PM
BUMP!!!
I have a seond transmission that i will try it on first...
#8 O.C.D.
O.C.D.
    Subaru Fanatic!
  • Validating
  • 690 posts
  • Colorado Springs
Posted 24 June 2013 - 09:09 AM
In for answer as I have my EA71 trans torn apart.  I see the 4WD selector shaft seal - it is about an inch wide.  Is this the same seal that is on the gear selector shaft?
