Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Now my Outback is overheating
#1
Posted 09 June 2006 - 05:01 AM
There is are normal liquid level in cooling system, both fan is working.
Next I like to do is change the thermostat.
the car has been drive round 45 k
Thanks
#2
Posted 09 June 2006 - 07:51 AM
Hi all and thanks for all. Now i have heating problem, in normal driving everything look right but when a drive a long high-pitched hill the temp. gauge start rising, when it came to almost red zone I stop the car and wait for a 10 min then the temp gauge was in normal again. Next time i drive the this hill I put heater system on full blow and the heat control on full heat. this was helping to keep temp. gauge rising.
Thanks
Sounds like classic airlock, have you recently done some cooling system work? SEARCH the site and find out how to 'burp' the cooling system. It's very important to get ALL the air out of the cooling system, you're stressing the head gaskets and will end up with HG failure.
#3
Posted 09 June 2006 - 09:02 AM
#4
Posted 09 June 2006 - 09:20 AM
the radiator could be plugged up.
no coolant loss?
are the fans turning on when the car starts to overheat?
i'd look into the radiator being plugged. when the car is warm...feel the hoses and make sure both are hot to the touch. a clogged radiator will often result in one of the hoses feeling "cold" to the touch.
after that i'd think about the water pump....not sure on how to test it.
#5
Posted 09 June 2006 - 09:34 AM
#6
Posted 09 June 2006 - 10:34 AM
Why did you change the T-state in the first place.
What year is this car. Another possability is a cloged radiator or low on coolant. Good news is that since you have hot heat its not a Head Gasket.
Are your cooling fans operating
nipper
#7
Posted 09 June 2006 - 11:46 AM
Yep has change thermostad got OE, how is the best way to get airpocket out of the engine ? this is 2003 Outback. No it has full coolant but maybe some isolate inside. What will best way to flush the cooling system ?Yoe changed the thermostate? go back and get an OE thermosta if you didnt install one. Next get the airpocket out of the engine, thats the cause of your trouble.
nipper
#8
Posted 09 June 2006 - 03:14 PM
ive always filled up the cooling system with the car running and thermostat open(thats how dad taught me), In all my soobies ive never had a air pocket. Another popular method is to drive the car on ramps and fill it.
i think your owners manual will point out the bleed points, if not somone wil chime in. i think there is a bleed valve on the top of the radiator, not sure.
nipper
#9
Posted 10 June 2006 - 08:41 AM
If i put heat to full on HVAC SYSTEM and the fan on full temp stop rising.:-\
#10
Posted 10 June 2006 - 09:19 AM
nipper
#11
Posted 10 June 2006 - 09:50 AM
Nipper, cooling fans is allmost all the time on, it is more like the circulation of the cooling liquid is unsatisfactory, two things, lose traction on belt which drive the waterpump or to hevy to turn the waterpump. Some broken in the water pump..... if the waterpump lose traction on the belt maybe the Autamatic belt tension is broken. How about that Nippersounds like your cooling fans arent coming on. The radiator flows from the bottom to the top, so i would double check the thermostate agauin, it may be in backwards. Another possability is a clogged radiator, but that is usually a hot bottom hose and cool top hose.
nipper
#12
Posted 10 June 2006 - 10:02 AM
What eyar make engine tranny and mileage is on the car please
#13
Posted 10 June 2006 - 10:33 AM
what year and whats the mileage on the car. i know you daid 45k but cant tell if that is how long you have owned it or thats total mileage on the car. If its 45K total on the car its WAY too early for either problem. If the waterpump drive belt was loose the timing belt would junp. Timing belt drives the water pumo.
the mileage is now 45.000 mile when i got it the mileage was 15.000 mile. Yes it is WAY too early..... but this is my problem today
#14
Posted 10 June 2006 - 10:40 AM
I have read almost all service manual to figure out what is broke or what is not working right.
is the car still under warrenty? Has the car had any major work done to it?
The symptons dont make sense to me, but im leaning more and more to a clogged raditor. Thw difference in the hose temp tells me there is no flow. ON the other hand the forced running of the cooling fans cools the car down. The more i think about it the more i think your radiator is cologed, but the questions is why?
Do you have a stick? What does the coolant look like? What color is your engine oil?
nipper
#15
Posted 10 June 2006 - 11:41 AM
ok, nipper the car was sold to Iceland from USA and all warrenty lost. yes I belive it has some major work before i buy it. Few minuts ago I open the time belt cover and on the back side on time belt did not look good, and when I start the motor a strange noice come from the waterpump, so definitely something is wrong with the waterpump.is the car still under warrenty? Has the car had any major work done to it?
nipper
#16
Posted 10 June 2006 - 01:07 PM
Then you have a bad waterpump, and if the car had some major work done, then i would suspect a cloged radiator too.
If somone here has a carfax account it would be interesting to run the vin # and see what history comes up. i bet it wont be pretty.
nipper
#17
Posted 10 June 2006 - 01:48 PM
Since the engine is already on an upward incline and the coolant-crossover outlet-pipe is centrally located, raising the front of the vehicle will most likely encourage even more air to get trapped toward the top of the front water jacket than it already does.Another popular method is to drive the car on ramps and fill it.
Usually I bounce the front of the vehicle hard with my knee while raising the RPM to dislodge and chase those stubborn air-pockets back toward the outlet.
I'd imagine this happens automatically during driving.
#18
Posted 26 July 2006 - 06:35 PM
#19
Posted 29 July 2006 - 12:48 AM
Hi all, yep Nipper i have change waterpump and belt tension, but it did not change. Next move is cloged radiator. today i drive about 400 mile and one every hill I have to turn on heating fan put it to max heat and max blow and that work out to keep the engine from overheating. But it was very hot inside the car, I have to open all the window to survive .....
A couple of posts back you stated the upper is hot and the lower hose is cool. That means the thermostat is not opening because of a lack of flow. airlock
Remove the radiator cap and warm up the engine and let it run for 20 min with the cap off. Watch for bubbles coming out the filler neck. You can massage the hoses to aid the process. Keep topping the filler neck off. At some point both hoses should be warm when the airlock moves and the thermostat opens.
Good Luck.
#20
Posted 29 July 2006 - 01:57 AM
The coolant flow into the top of the radiator. When the thermostat opens the water pump draws in coolant through the lower hose and mixes this with the warmer stuff coming back from the engine block.
#21
Posted 14 August 2006 - 06:14 PM
Last Friday I put new radiator and that fix my heating prob. When the workshopman open the old radiator we see it was almost all clogged. Now my outback run fine.And just to be accurate:
#22
Posted 14 August 2006 - 08:27 PM
Yay! There's happiness in Iceland. Way to go, Boddi!
