Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Tow Hitch on 1999 Legacy Outback
#1
Posted 09 June 2006 - 09:05 PM
I want to put a tow hitch on my outback so I can tow my dirtbike.
The only available hitches for the legacy outback are Class 2, 3000 pound tow limit and 300 pound tongue weight and has a 1 1/4in reciever.
I would like to get a dirtbike rack which weighs about 25 pounds but it requires a class 3 hitch with a 2inx2in reciever hole.
Now my dirtbike weight 190 pounds, would it be safe to get an adapter for the hitch from 1 1/4in (class 2) to the 2inx2in (class 3)? I'd really rather a rack instead of a trailer. I would be well under the tongue limit for the hitch rating.
The rack basically looks like a platform perpendicular to the car with a square tube the plugs into the hitch.
Thanks,
edit- well i just checked the owners manual and it said the tongue weight limit was 165 pounds, even though the u haul hitch i'm getting is rated to 3000 trailer weight/300 tongue weight... So I guess there is no safe way to put my bike on a rack?
Will
#2
Posted 09 June 2006 - 09:52 PM
Here is my problem...
Thanks,
Will
I've got a bicycle rack that's the same way, 2" x 2" "tongue". I'm going to cut the 1 1/4 x 1 1/4 receiver off the hitch I'll eventually get and weld (or have welded) on a 2 x 2 receiver.
You can check the math on the tongue weight to be sure:
Assume a ball is about 6" away from the rear of the receiver opening, 300lbs x 6" = 1800 in-lbs of torque on the hitch. Now take the weight of the tray/rack plus the weight of the bike, measure the distance from the rear of the receiver opening to where the bike sits and do the math. Example:
Bike and rack, 200 lbs
Distance from receiver to bike tires, 18"
200lbs x 18" = 3600 in-lbs, twice what the hitch is rated for.
Or you can go backwards and figure out how much weight you can handle if you know the distance:
1800 in-lbs/18" = 100lbs You could only put 100 lbs 18" out from the receiver and be at the rating for tongue weight. That's not much. Might need to figure out a way to beef up the hitch. I might have to just for my bike rack after doing this math.
Monte
