Ej 5speed-welding center diff?
9 replies to this topic
#1 sayn3ver
sayn3ver
    Eat, Live, Breath Subaru
  • 255 posts
  • South Jersey
Posted 12 June 2006 - 08:58 PM
Could one make a locled center diff for a subaru by welding it together or welding a spool into it?
Would this bind like a mother on the street?
i am assuming it would bind...
I also came across on MRt's website, they sell a spool which makes your subaru RWD, interested for those who wanna run a transfer case.
#2 Andyjo
Andyjo
    I'm Not Austin!
  • 1,808 posts
  • Windham NH
Posted 12 June 2006 - 09:19 PM
Well.. as it is, i don't think you could do it... because well... viscous things don't weld well.... :rolleyes:
As for a shaft... to make your subi RWD... why.....
do you have another car to drive? because i don't think you want to be messing w/ the awd that much...
#3 sayn3ver
sayn3ver
  • 255 posts
  • South Jersey
Posted 12 June 2006 - 09:29 PM
I guess i am trying to find a cheap way to get some lockage going for offroad. Weak viscous lsds are no fun.:(
I guess i'll have to somehow squeeze a dual range into my car, if i could ever find one and someone who can fab up axels for me.
And from my reading, the Vlsd can be welded or atleast thats how people are making it out to be.
#4 Andyjo
Andyjo
    I'm Not Austin!
  • 1,808 posts
  • Windham NH
Posted 12 June 2006 - 10:09 PM
fwd impreza axles work.
and there's d/r's all over the place up here :)
you'd also need an adapter plate.. a different flywheel (or have yours re-drilled), and figure out a read drive shaft... either weld em together, or have a custom one built.
#5 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,099 posts
  • NH
Posted 12 June 2006 - 10:31 PM
There is a differential in there with spider gears. It has a viscous limited slip device attached to it.
#6 Numbchux
Numbchux
    EJ conversion addict
  • 6,811 posts
  • Saginaw, MN
Posted 13 June 2006 - 01:52 AM
yes, the center diff can be welded. there's a local guy running hi L wagon with RWD right now.
yes, it would bind horribly on the street....don't do it
yes, FWD impreza axles fit right onto EA part-time 4WD Dual Range trannies and into your hubs (correct me if I"m wrong here, is there a difference between legacy and imp hubs?, otherwise you could probably swap the 23-spline inner cups onto your legacy axles)
#7 sayn3ver
sayn3ver
  • 255 posts
  • South Jersey
Posted 13 June 2006 - 09:41 AM
i have an impreza
#8 970subaru
970subaru
    Subaru Fanatic!
  • 461 posts
  • Seattle, WA
Posted 13 June 2006 - 09:47 AM
here is a sweet how to
http://www.clubwrx.n...ead.php?t=27532
I would try and find a toasted center diff to weld up beforehand, make it go a lot quicker.
then put on a divorced toyota case and toyota axles :D
#9 sayn3ver
sayn3ver
  • 255 posts
  • South Jersey
Posted 13 June 2006 - 08:12 PM
transfer cases require alot of work. :confused:
i thought they did.
#10 LosDiosDeVerde86
LosDiosDeVerde86
    1000+ Super USER!
  • 1,358 posts
  • Columbus
Posted 13 June 2006 - 10:53 PM
...said Mr. 4wd DutyC Lock Man
