source4bearings4 T belt idler pulleys???
2 replies to this topic
#1 bgambino
bgambino
    Subaru Nut
  • 710 posts
  • new york
Posted 15 June 2006 - 08:55 PM
I'd like to get new bearing and have them pressed into a couple of my idler pulleys (96 DOHC 2.5 OB)....especially the toothed idler...I bet this sucker is costly
Went to car quest..they looked up he bearing numbers I gave them and said no good
Anyone?
Also....is 1st subaru still in existence? I thought they sold OEM parts about 10% over cost.
Someone said there is a difference between the website and calling in (differing prices)
thanks
#2 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 15 June 2006 - 09:12 PM
https://www.subaruge..._parts_cat.html
try here. If you need to call ask for Jamie, shes on this board.
nipper
#3 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,008 posts
  • East Coast
Posted 16 June 2006 - 12:18 AM
your best bet would be to get the numbers off the face of the pulleys and any bearing supply house can match those numbers with the correct bearings.
if i were you i'd get an entire set of used pulleys. i'm sure there are plenty lying around, i have some from a 2.5 SOHC sitting somewhere. post in the parts wanted forum or find a junkyard that has a bad motor. or go to a pull it yourself yard and get a set of old pulleys. get these all rebuilt that way you have new pulleys ready to go when you do the timing belt job.
