Please help Me ID this Clutch Cable [Pic]
9 replies to this topic
#1 MSSLGECKO
MSSLGECKO
    Certified Subaru Nut
  • 755 posts
  • Missoula
Posted 19 June 2006 - 05:49 PM
I'm having trouble finding the correct replacement for my old clutch cable.
The reason that I don't know the part # I need is that my car was originally a 3SPD and had the '87(?) D/R when I got it. If someone knows EA clutch cables, I could use your expertise . . . I think that it may be an EA81 model cable, but seem irregularly long. .
Posted Image
The part that I'm looking for has the pedal end (left side of pic) designed to be held not by bolts, but rather by a metal band that is held by one screw and sits over the cable.
If someone can identify the specific model this is from or the part numer, that would really help me out! I think the overall length is ~35" (Napa had similar ones in the comp. that were like 10"s too short. . .)
#2 4x4_Welder
4x4_Welder
    Just a guy
  • 1,131 posts
  • Rexburg, ID
Posted 19 June 2006 - 07:14 PM
Looks exactly like the one in my 81 GL Hatch. That cable is going to be halfway long, since the clutch release is on the passenger side.
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,690 posts
  • Portland
Posted 19 June 2006 - 07:16 PM
That's an EA81 cable for like 80-83.5, after that they changed the pedal end to a spring clip like the clutch fork side. There shouldn't be any real difference in the length of the two EA81 type cables. DO NOT buy an aftermarket cable - they are inferior, and the OEM one is only like $12.
Get a cable for an 82 GL and you should be good.
#4 Davalos
Davalos
    Subaru Fanatic!
  • 431 posts
  • Ann Arbor MI
Posted 19 June 2006 - 08:03 PM
I remember doing my clutch cable not too long ago. I also remember having a really had time with the connections @ the petal being different than what I read in the book... not to mention the tight squeeze of getting my head & shoulders in there ...
I'll try & rack my brain ... seems to me there was a spring-clip rather than a cotter pin, or something like that ... the rest went fairly well - took maybe 2 hours WITH the trip to the hardware store for another clip.
Mine is an aftermarket ... so far so good, but like I say - less than 2 months ago... (gulp).
After getting an $11 key copied and a $18 fusible link from the dealer, I didn't even ask about the clutch cable ...
#5 MSSLGECKO
MSSLGECKO
  • 755 posts
  • Missoula
Posted 19 June 2006 - 08:54 PM
Thanks, I'll check it out at the stealership!
#6 GeneralDisorder
GeneralDisorder
  • 21,690 posts
  • Portland
Posted 19 June 2006 - 10:07 PM
EA82's are not the same.
Here's my write up on the situation:
http://home.comcast....ear/clutch.html
#7 MSSLGECKO
MSSLGECKO
  • 755 posts
  • Missoula
Posted 19 June 2006 - 11:02 PM
Thanks GD! That's a great write-up w/ pics, and explains to me why the '84 cable that I saw in the napa database looked a little off.
I think the (incorrect) cable I got at napa was ~$25, do you know off hand what the OEM part costs?
#8 GeneralDisorder
GeneralDisorder
  • 21,690 posts
  • Portland
Posted 20 June 2006 - 12:28 AM
I think last time I got one it was about $13.... wholesale (my local dealer rocks!), I think retail is around $17 or maybe a bit more. Depends on the dealer really.
#9 MSSLGECKO
MSSLGECKO
  • 755 posts
  • Missoula
Posted 23 June 2006 - 06:57 PM
I got the right part from the dealership for ~$18 and installed it. Thanks for the help ID'ing the part!
General - I'm impressed by how thorough your write-up is. Do you have any more awesome documents to share?:headbang:
#10 GeneralDisorder
GeneralDisorder
  • 21,690 posts
  • Portland
Posted 23 June 2006 - 08:00 PM
I'm a lazy bum, and haven't got around to doing many - that one, and the axle cup mod ( http://home.comcast....rebuilding.html ) are really the only two I have done to date. I plan on doing an axle removal/replacement one, and I really should do something on the rear discs.... but I need to shoot video for that one. Also about to embark on EA81 SPFI, but I went and cut the wrong tab off the disty I modded :rolleyes:. My Brat sits patiently waiting for the 100 degree heat to pass.
Really I should take pictures anytime I'm out there - plenty of write ups I *could* do if I quit my job and dumped my girlfriend.... really need to start on the t-case w/custom long travel suspension. All in time I suppose. For now feel free to PM me - I'll help as best I can.
