Need a little more info for 94 imp DR Swap
7 replies to this topic
#1 JordanR693
JordanR693
    USMB Regular
  • PipPipPip
  • 96 posts
  • Louisville
Posted 21 June 2006 - 05:19 PM
Yea i have access to anything and more than nessesary to do this swap now so it is time. I need to know if i use the rear diff off of the ea-82 is that the best choice? and which axles for the front and rear? I have heard fwd Impreza axles will do the job for the rear but havnt heard much on the front how many splines are the axles on the stock 94 imp vs. the ea-82 5speed DR Trans? Will it be a possible task to throw a e or air locker on that 3.9? I was thinking of using my ac compressor for an air locker. I have access to all parts i need for the most part and i just need this last bit of info.
Thanks
Jordan
if there is anything else you feel i need to know feel free to shoot.
#2 88HatchMonster
88HatchMonster
    Back in the Hatch
  • 486 posts
  • South Burlington, VT
Posted 21 June 2006 - 08:14 PM
Please forget about the air locker for now, it's been discussed here ad infinitum and no one's actually ever done it with stock subie diffs.
As for using the rear diff off of the EA82--it's only necessary if your impreza doesn't have 3.9 gearing already. Check the sticker on your diff to find out.
There is no need to change your rear axles.
It's the front that you need to use the FWD imp axles for. Here's why:
AWD Impreza front axle spline count: 25
4WD N/A EA82 D/R front axle spline count: 23
FWD Impreza front axle spline count: 23
I hope that is clear enough! :) good luck!
#3 Andyjo
Andyjo
    I'm Not Austin!
  • 1,808 posts
  • Windham NH
Posted 21 June 2006 - 08:17 PM
You need the good ol' adapter plate too, and most likely a custom driveshaft.
As for air lockers... yeah... you've got some other things to do before you start thinking about that... like building your own machine shop...
#4 Numbchux
Numbchux
    EJ conversion addict
  • 6,827 posts
  • Saginaw, MN
Posted 22 June 2006 - 12:20 AM
FWD imprezas don't have rear axles :lol:
hatch monster's got it all right for the spline counts
you can use your A/C compressor for on board air, for refilling your tires after airing them down, for air tools, etc. but nobody makes an air locker for a subaru.
#5 JordanR693
JordanR693
    USMB Regular
  • PipPipPip
  • 96 posts
  • Louisville
Posted 22 June 2006 - 10:27 PM
Oh i can just change the cvs and stuff on my axles and get a different spline count but i might just go with the fwd axles.
#6 JordanR693
JordanR693
    USMB Regular
  • PipPipPip
  • 96 posts
  • Louisville
I think i can find a way to do a air locker ill let you all know what happens when i get the diff. My boss said i could deffinitally do it
#7 JordanR693
JordanR693
    USMB Regular
  • PipPipPip
  • 96 posts
  • Louisville
Posted 22 June 2006 - 10:30 PM
We trade work for work with machine shops. I work in a performance shop so i think the machining and flywheel redrilling wont be a problem. I will probably just buy the adapter plate. I already knew about those things. I will make my own Crossmember
#8 JordanR693
JordanR693
    USMB Regular
  • PipPipPip
  • 96 posts
  • Louisville
Im going ahead and putting my M/Ts on this weekend. Ill try to get a pic on here
