CEL, Vehicle Speed Sensor
2 replies to this topic
#1 bearbalu
bearbalu
    USMB is life!
  • 182 posts
Posted 24 June 2006 - 02:19 PM
I have 0500, P1540 - it appears to be VSS2.
Before I replace it, I want to be sure it is bad. What electrical diagnostics should I run on the two wire wire connector that come out of the VSS
#2 nipper
nipper
    Semi Elite Master of the
  • 18,191 posts
  • Long Island NY
Posted 24 June 2006 - 03:24 PM
There are few things that when you get a failure code, it truly is that part, especially when it is just a single code.
VSS
crank position sensor
cam postion sesnor
o2 sensor
No one has ever rpelaced one of these when its failed and said that wasnt the problem.
so go ahead and replace it
nipper
#3 d-hunter1
d-hunter1
    Newbie
  • Pip
  • 2 posts
  • VA
Posted 08 November 2013 - 07:24 PM
Not nessasarily Nipper. Sorry but if the spedo is still working it may just be as simple as loose screws behind the cluster.
