Weber Install: What do I tap my choke wire into?
5 replies to this topic
#1 TheSubaruJunkie
TheSubaruJunkie
    Subaru Sober since 2010 :(
  • 1,907 posts
  • Sacramento
Posted 24 June 2006 - 04:29 PM
Im finishing up my weber install... last thing I gotta do is wire the electric choke? What do I tap into???
THanks,
-Brian
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,278 posts
  • Portland
Posted 24 June 2006 - 04:58 PM
Should be a 3 wire connector for the Hitachi - two of those are hot in run at all times - one is for the electric choke on the Hitachi, and the other is for the idle fuel cut solenoid. Just take the pig-tail off the Hitachi, and run the same wire to the choke that was being used before.
#3 TheSubaruJunkie
TheSubaruJunkie
  • 1,907 posts
  • Sacramento
Posted 24 June 2006 - 05:01 PM
Gotchya....
thanks
-Brian
#4 Flowmastered87GL
Flowmastered87GL
    WCSS Drunk
  • Gold Subscribers
  • 6,026 posts
  • Portland, Oregon
Posted 24 June 2006 - 09:11 PM
Make sure to insulate the unused wires well plus make sure the choke wire is on there nice and tight. Mine came free once and made be blow a fuse :-\
#5 GeneralDisorder
GeneralDisorder
  • 20,278 posts
  • Portland
Posted 24 June 2006 - 09:48 PM
Yes indeed - and on the EA81 that same fuse controls the Brake lamps :confused:, so you'll know real quick when the cops pull you over.
#6 TheSubaruJunkie
TheSubaruJunkie
  • 1,907 posts
  • Sacramento
Posted 24 June 2006 - 10:02 PM
Ah... good point, i left them hanging there. I'll have to make sure i go back and take care of that.
-Brian
