Meeky Moose Posted October 31, 2003 Share Posted October 31, 2003 just wondering if there is any difference between the 2wd flywheel, pressureplate, clutch, etc in a 2wd 5-speed ea82t and a 4wd 5-speed ea82t? also is there any difference in front rotors? Quote Link to comment Share on other sites More sharing options...
MorganM Posted October 31, 2003 Share Posted October 31, 2003 Indeed there is a big difference. The 4WD clutch plate and pressure plate are considerably larger. As a resulte the flywheel is machined to fit the larger sized components. I know little about the rotors, sorry! Quote Link to comment Share on other sites More sharing options...
WJM Posted October 31, 2003 Share Posted October 31, 2003 I believe ALL front rotors on ALL EA82 cars are the same. WIth regard to the clutch...I have a 2wd XT turbo 5spd, it uses the same clutch set as any 4wd EA82 car, even the XT6. I dont know for sure about the L series EA82 cars, but this is what I know... 2wd, non-turbo Leone/Loyale use the 7 inch clutch (7 and 7/8 to be exact, IIRC) and 23 spline axles. 2wd, turbo XT's use 25 spline and 8 (8 and 7/8) inch. 4wd non-T Leone/Loyale use 23 spline and 8 inch clutch (from what I have seen) ALL 4wd Turbos use 8 inch clutch and 25 spline. It seems like all XTs have 25 spline and the large clutch, but i have not confirmed this on the non-turbo XTs. XT6 uses 8 inch and 25 spline. *note this listing is for 5spd trans ONLY* For Autos, I have yet to see any 2wd or 4wd that uses the 25 spline. My GL-10 when it was an auto 2wd had 23 spline. Ofcourse, i have no clue about different T-converters. Quote Link to comment Share on other sites More sharing options...
Meeky Moose Posted November 1, 2003 Author Share Posted November 1, 2003 just the info i was lookin for, i knew someone would have better insight than me i do remember when i bought the parts that the flyheel and clutch were bigger than a n/a because its a turbo.. and i seem to remember someone sayin an xt6 clutch is the same.. so i thought that since both cars are ea82T and 5-speed that the parts would interchange.. only difference really is one tranny is d/r 4wd and one is 2wd.. and i knew about the spline difference between n/a and turbo cars.. thanks WJM Quote Link to comment Share on other sites More sharing options...
WJM Posted November 1, 2003 Share Posted November 1, 2003 no prob! Quote Link to comment Share on other sites More sharing options...
jaytee5211 Posted March 11, 2016 Share Posted March 11, 2016 So can I use a non turbo 4wd flywheel/clutch combo on a 2wd car. I have a 93 loyale ea82 Quote Link to comment Share on other sites More sharing options...
