axle tool
8 replies to this topic
#1 Guest_baccaruda_*
Guest_baccaruda_*
  • Guests
Posted 14 August 2003 - 01:02 AM
Can I get the PN for the axle installation tool please? sad when the dealer doesn't know :mad:
#2 Guest_OH Noah_*
Guest_OH Noah_*
  • Guests
Posted 14 August 2003 - 05:50 AM
My FSM says it's 925130000
#3 Guest_baccaruda_*
Guest_baccaruda_*
  • Guests
Posted 14 August 2003 - 09:20 AM
thanks!
#4 Guest_archemitis_*
Guest_archemitis_*
  • Guests
Posted 14 August 2003 - 10:06 AM
what is this tool for? axles just slide right in right?
#5 Guest_GeneralDisorder_*
  • Guests
Posted 14 August 2003 - 11:08 AM
The tool helps to get it back in. They fit tight, and it's a bit difficult to get them in sometimes. Getting it out is easy - block of wood, and BFH.
#6 Guest_OH Noah_*
Guest_OH Noah_*
  • Guests
Posted 14 August 2003 - 11:27 AM
If you're installing a used (or rebuilt) axle into used bearings, then it will often just slide right in. On the other hand, if you are installing a new axle into new bearings you usually need some help, as it's supposed to be a press fit.
I usually use a slide hammer with 3-claw attachment attached to the axle nut.
#7 Guest_MilesFox_*
Guest_MilesFox_*
  • Guests
Posted 14 August 2003 - 11:22 PM
i'll put the axle on the tranny end, and then tap the knuckle onto the axle before i fit the ball joint. the nut will do the rest
my 2 cents (and costs less!)
#8 Guest_baccaruda_*
Guest_baccaruda_*
  • Guests
Posted 15 August 2003 - 01:20 AM
i usually crawl under and push the axle against the tranny right next to the stub and put a jack stand under it.. then i pound on the hub till i can get the axle over the stub..
i've tried crawling under the whole car and pushing the knuckle, etc out with my feet, and i can get the axle on the stub before i do any pounding, but i'd rather pick up the right tool..
wasn't someone making tools for this out of their shop?
#9 Guest_chef tim_*
Guest_chef tim_*
  • Guests
Posted 15 August 2003 - 06:25 AM
I built my own. Very simple design, saves alot of time, heart ache, cussing, etc etc. Tim
