Guest baccaruda Posted August 14, 2003 Share Posted August 14, 2003 Can I get the PN for the axle installation tool please? sad when the dealer doesn't know Quote Link to comment Share on other sites More sharing options...
Guest OH Noah Posted August 14, 2003 Share Posted August 14, 2003 My FSM says it's 925130000 Quote Link to comment Share on other sites More sharing options...
Guest baccaruda Posted August 14, 2003 Share Posted August 14, 2003 thanks! Quote Link to comment Share on other sites More sharing options...
Guest archemitis Posted August 14, 2003 Share Posted August 14, 2003 what is this tool for? axles just slide right in right? Quote Link to comment Share on other sites More sharing options...
Guest GeneralDisorder Posted August 14, 2003 Share Posted August 14, 2003 The tool helps to get it back in. They fit tight, and it's a bit difficult to get them in sometimes. Getting it out is easy - block of wood, and BFH. GD Quote Link to comment Share on other sites More sharing options...
Guest OH Noah Posted August 14, 2003 Share Posted August 14, 2003 If you're installing a used (or rebuilt) axle into used bearings, then it will often just slide right in. On the other hand, if you are installing a new axle into new bearings you usually need some help, as it's supposed to be a press fit. I usually use a slide hammer with 3-claw attachment attached to the axle nut. Quote Link to comment Share on other sites More sharing options...
Guest MilesFox Posted August 15, 2003 Share Posted August 15, 2003 i'll put the axle on the tranny end, and then tap the knuckle onto the axle before i fit the ball joint. the nut will do the rest my 2 cents (and costs less!) Quote Link to comment Share on other sites More sharing options...
Guest baccaruda Posted August 15, 2003 Share Posted August 15, 2003 i usually crawl under and push the axle against the tranny right next to the stub and put a jack stand under it.. then i pound on the hub till i can get the axle over the stub.. i've tried crawling under the whole car and pushing the knuckle, etc out with my feet, and i can get the axle on the stub before i do any pounding, but i'd rather pick up the right tool.. wasn't someone making tools for this out of their shop? Quote Link to comment Share on other sites More sharing options...
Guest chef tim Posted August 15, 2003 Share Posted August 15, 2003 I built my own. Very simple design, saves alot of time, heart ache, cussing, etc etc. Tim Quote Link to comment Share on other sites More sharing options...
