Soobie wont crank right up..
5 replies to this topic
#1 Roamer
Roamer
    USMB Regular
  • PipPipPip
  • 102 posts
  • Queens
Posted 01 July 2006 - 01:10 PM
On my 96 LSI wagon I am getting intermitant starting issues, here is the deal, when I go to start the car I turn the key but nothing happens as if the car has no juice, but the radio and everything works fine, then I go to turn the key again and the car starts and runs fine. I never thought anything of it but it seems to be getting worse, now I have to turn the key 3 or 4x before I get a response from the car to start. I am thinking it might be corroded battery connectors or signs of a starter going bad? I have no CEL on, any thoughts or input is appreciated..Thanks in advance.
#2 ()__1337_CRAYOLA__()>
    Soob Finatic
  • 621 posts
  • Burien/Des Moines
Posted 01 July 2006 - 01:23 PM
When you turn the key to where the starter should engauge is the radio and everything else shutting down or do they just keep going, they should shut off for the time you try to engauge the starter to where you let off. maybe it is your ignition switch
#3 Roamer
Roamer
    USMB Regular
  • PipPipPip
  • 102 posts
  • Queens
Posted 01 July 2006 - 02:05 PM
[quote name='()__1337_CRAYOLA__()>]When you turn the key to where the starter should engauge is the radio and everything else shutting down or do they just keep going' date=' they should shut off for the time you try to engauge the starter to where you let off. maybe it is your ignition switch[/quote']
No they do shut-off for the time that I am trying to engage, and come back on when I turn the key back.
#4 99Impreza
99Impreza
    New User
  • Pip
  • 3 posts
  • N. Seattle
Posted 01 July 2006 - 02:18 PM
Check the voltage at the starter crank wire. It's the little wire on the starter solenoid. Have a budy check it while you turn the key to crank. Crank the key a couple of times to make sure. If you have voltage there consistently (it should be 12v) then check to see if you have excesive resistance in the wire from the battery to the starter solenoid and the battery connector to the battery terminal. If all that checks out you could need a new starter. :headbang:
#5 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,064 posts
  • Honolulu HI
Posted 01 July 2006 - 02:47 PM
Could it be the starter contacts? Common problem, relatively cheap and easy fix. Try a search under "starter contacts."
#6 pamike
pamike
    Subaru Fanatic!
  • 383 posts
  • Jersey Shore, PA
Posted 01 July 2006 - 05:45 PM
my 90 did the same thing and it was the starter. shortly after it started that, i went to start it and it wouldn't stop cranking even with the key off. i had to pull the battery cable off to stop it. i replaced the starter and everything has been fine.
