EA82 Turbo manifolds
5 replies to this topic
#1 Tosh
Tosh
    Subaru Fanatic!
  • 360 posts
  • Centralia, WA
Posted 04 July 2006 - 05:02 PM
aftermarket ones ? preferably one that would let me bolt up a bigger turbo say out of WRX/STI. I heard Tech Works Engineering made them but I can't find any on their website and I sent them a few e-mails with no responce. Anyone know how to get one of their mani's or who else I could get one from ?
#2 4WDFrenzy
4WDFrenzy
    Certified Subaru Nut
  • 857 posts
Posted 04 July 2006 - 08:17 PM
The only thing that I could tell you is to get an uppipe from a WRX and cut the mounting flange off. Then get whatever header you want(that will fit the EA82T), or have a custom one made, and have the flange welded in place. You might also want to have a flexpipe welded into the uppipe portion of the header to keep the welds on the flange from breaking loose(common to stock EA82T exhaust manifolds after adding a custom downpipe and exhaust system).
Patrick
#3 [HTi]Johnson
[HTi]Johnson
    Head Trauma, inc.
  • 1,522 posts
  • Coburg, Or.
Posted 04 July 2006 - 09:27 PM
The only time I've had the turbo flange break off the up pipe is when I did not have the downpipe secured to the transmission where the stock Down pipe does.
#4 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 05 July 2006 - 12:51 AM
Make friends with your local exhaust guys.
Personally, I am using the stock header with my TD04.
For the price of the TWE header I was able to get: A TD04, flange to mount it to the stock uppipe, a custom 2.5 inch turbo back exhaust and a little custom IC piping.
Not saying the header is bad.. But its not the only improvement one can make.
#5 Elroy Jetson
Elroy Jetson
    USMB Regular
  • PipPipPip
  • 77 posts
  • Martinsburg
Posted 05 July 2006 - 06:13 PM
The ones on the 87.5 and later XT model years had much nicer "spider" type manifold. Came only on the 4 cylinder XT models with the "hot wire" MAF's so you'll need to convert to the "hot wire" injection system including the ECU.
#6 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 05 July 2006 - 08:14 PM
exhaust manifold ;)
