I am looking for a good source for a full engine rebuild kit (gaskets and pistons/bearings). What are some good companies? so far all I have found is re-ring kits or "performance" kits. It is a non turbo - and I would just like an oem rebuild kit.
The thing has major piston slap and leaks oil bad.
also - what about a clock spring?
thank you
sam
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
98 forester rebuild kits
Started by
skunkworks
, Jul 05 2006 06:33 PM
3 replies to this topic
#1
Posted 05 July 2006 - 06:33 PM
#2
Posted 05 July 2006 - 07:43 PM
Actually i always bought my engine kits from JC whitney (all brand name parts), and in 3 engines i never had a problem. To ensure a proper kit match, you may need to take the engine apart first and measure the crank journals to make sure you get the proper bearings.
Also to cure piston slap you are going to have to get the two pistons that sooby uses to correct slap, otherwise your going to get it again.
clock spring will be a sooby part only
https://www.subaruge..._parts_cat.html
nipper
nipper
#3
Posted 10 July 2006 - 01:31 PM
Thank you.
so there is 2 pistons required from subaru - or version 2 pistons?
if it is 2 pistons - what was changed compared to the other ones?
thanks
sam
thanks
sam
#4
Posted 10 July 2006 - 03:31 PM
Thank you.
thanks
sam
ask Jamie, im not sure if the are a repair part or a superceeded part .
nipper
