BlueSteel Posted July 6, 2006 Share Posted July 6, 2006 Ball Tearer Brumby lifted from AutoSpeed Magazine http://autospeed.drive.com.au/cms/A_2970/article.html One of Australia's most impressive AWD drag machines - and probably the world's best Brumby! World's fastest Subaru Brumby? 2.4-litre EJ-series four Currently 498hp (372kW) at all fours Soon into the 9s Immaculately presented Occasionally street driven! The engine comprises a 2.2-litre EJ-series block with a 2.4-litre aftermarket stroker kit, forged pistons and rods and modified DOHC heads. Oversize valves and custom cams give extra breathing capacity. The engine is built with an aftermarket stud kit and all the good bits you’d expect in a drag motor. A PWR aluminium radiator and Davies Craig 10 inch thermo fan keep it running cool. An off-the-shelf exhaust manifold and custom up-pipe connect a Garrett GT35/40 turbo combined with a 42mm external gate. With boost set to a max of around 25 psi, the heated charge air is chilled by a PWR barrel-style water-to-air intercooler. Interestingly, the water lines for the water-to-air ‘cooler pass through an esky which is mounted behind the cabin - Nathan throws in a couple of bags of ice to help reduce peak intake air temps from around 45 to 10 degrees Celsius. Stainless plumbing routes through the engine bay and a single TurboSmart blow-off valve is installed. The intake to the turbo comprises a large pod filter on the end of a mandrel bent length of tube while exhaust gasses exit via a 3 ½ inch system with twin 3 ½ inch straight-through mufflers. Interestingly, the engine runs a custom intake manifold that – while it appears similar to the stocker – provides perfectly even length runners and a custom plenum volume. A big-bore billet throttle ensures there’s plenty of airflow into the intake manifold. Controlling the fuel and ignition systems is a MoTeC M400 programmable ECU with data logging and various other options ‘unlocked’. Rochester 1000cc injectors suckle from custom rails teamed with an AEM pressure regulator and you’ll find large diameter braided lines extending back to the Magnafuel pump teamed with twin Bosch 044s pumps. A custom alloy fuel tank (with extensive internal baffling) is mounted under the tray. The CDI ignition system is controlled by the MoTeC and Mercury Marine ignitors are employed. Tuning (and much of the drag setup) has been performed by the experienced team at Advanced Performance Centre is Brisbane. Quote Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted July 7, 2006 Share Posted July 7, 2006 :headbang: Quote Link to comment Share on other sites More sharing options...
jeffast Posted July 7, 2006 Share Posted July 7, 2006 i second that :headbang: :headbang: Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted July 7, 2006 Share Posted July 7, 2006 Quote Link to comment Share on other sites More sharing options...
monstaru Posted July 7, 2006 Share Posted July 7, 2006 ummm,willsomebody pick me up off of the floor ,it really hurts to type like this. Quote Link to comment Share on other sites More sharing options...
lastchance Posted July 7, 2006 Share Posted July 7, 2006 rigoli brat>that brat Quote Link to comment Share on other sites More sharing options...
Matty B Posted July 7, 2006 Share Posted July 7, 2006 rigoli brat>that brat Bulldust! Where in the world can you drive a car with no air cleaner and a great big turbo sticking THROUGH the hood? This thing is slick, without the stickers you could drive it anywhere. And pull 10 second passes. Quote Link to comment Share on other sites More sharing options...
lastchance Posted July 7, 2006 Share Posted July 7, 2006 Bulldust! Where in the world can you drive a car with no air cleaner and a great big turbo sticking THROUGH the hood? This thing is slick, without the stickers you could drive it anywhere. And pull 10 second passes. i still stand by my earlier statment. Quote Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted July 7, 2006 Share Posted July 7, 2006 are those impreza hubs and disks? Quote Link to comment Share on other sites More sharing options...
Matty B Posted July 7, 2006 Share Posted July 7, 2006 WRX hubs and discs. Quote Link to comment Share on other sites More sharing options...
BlueSteel Posted July 7, 2006 Author Share Posted July 7, 2006 the full article is in this thread http://ausubaru.com/main/modules.php?name=Forums&file=viewtopic&t=3033&highlight= Quote Link to comment Share on other sites More sharing options...
rguyver Posted July 7, 2006 Share Posted July 7, 2006 well i gess he has set the bar high any one gona step up Ill have some work to get my Brat in the 9's i'm hoping for mid 12's Quote Link to comment Share on other sites More sharing options...
Phizinza Posted July 7, 2006 Share Posted July 7, 2006 Where in the world can you drive a car with no air cleaner and a great big turbo sticking THROUGH the hood. I've seen the TRP Brumby in a video (in Autobarn) driving on a country (looking) road. I also have a video of it on a dyno getting 495hp.But I think they are both cool. I just wouldn't do that hinda thing to a ute, :-\ EDIT!:: I love the dash in that thing... I want to do mine like that hehe Quote Link to comment Share on other sites More sharing options...
baccaruda Posted July 7, 2006 Share Posted July 7, 2006 I am booking a flight to Oz and stealing that thing. interesting that there's no strut tower brace in that picture... Quote Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted July 8, 2006 Share Posted July 8, 2006 interesting that there's no strut tower brace in that picture... only need a tower brace if your cornering hard no brace = less weight for going fast in a straight line Quote Link to comment Share on other sites More sharing options...
Turbone Posted July 8, 2006 Share Posted July 8, 2006 Nicely done:D I assume the tires in the pics are for street use. Otherwise it would just fling the meat right off the wheels. As light as the car is, I bet its a bear to get a hook up. Quote Link to comment Share on other sites More sharing options...
baccaruda Posted July 8, 2006 Share Posted July 8, 2006 yeah, but I'll bet he has one for it somewhere only need a tower brace if your cornering hard no brace = less weight for going fast in a straight line Quote Link to comment Share on other sites More sharing options...
Uberoo Posted July 8, 2006 Share Posted July 8, 2006 id race it. OFFROAD.... Quote Link to comment Share on other sites More sharing options...
waimaks Posted July 9, 2006 Share Posted July 9, 2006 The whole article can be read somewhere on this thread.... http://www.ausubaru.com/main/modules.php?name=Forums&file=viewtopic&t=3033&postdays=0&postorder=asc&start=0 Yay for Brumbys Quote Link to comment Share on other sites More sharing options...
