rth009 Posted July 9, 2006 Share Posted July 9, 2006 1991 Loyale 4wd A few months ago I noticed that my rear tires were wearing unevenly. I took it to the Subaru dealer for rear wheel alignment. They told me it was wayout of alignment but that they had fixed it. They did not suggest that I needed any new parts in order for the rear wheels to remain in alignment, although they told me that numerous other things were wrong on the car. Now, 4 months later, the rear tires are again wearing unevenly - although a bit differently than before? Question: What potential parts need replaced in order for the rear wheel alignment to "hold?"? Question: What should I tell the subaru dealer when I take it back for repair? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 9, 2006 Share Posted July 9, 2006 What will really blow your mind is there are no adjustments for rear wheel alignment on a Loyale. The rear has trailing arms, and they are bolted to the control arms, and the "tube" with 3 bolts. Generally if you are seeing strange tire wear in the rear it's because something back there is bent, or the wheel bearings are shot (this would make horrible noises, and probably fail quickly tho). I've seen plenty of bent rear control arms - usually from sliding into curbs and such. I don't know what that dealer did, but I wouldn't take it back there again. GD Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 9, 2006 Share Posted July 9, 2006 Rick is right. Loyales have no rear wheel adjustments. If the camber is messed up on the rear of your car, something is bent. The dealership should have known that, as well as the mechanic who worked on your car. I would go back and b!tch them out. -Brian Quote Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted July 10, 2006 Share Posted July 10, 2006 Unless Loyale's differ from 85-89 dl/gl/gl-10/rxs in rear supension design, according to FSM rear alignment IS adjustable both camber and Toe..those same three bolts that hold the inner and outer trailing arms to each other are where the alignment can be adjusted..according to FSM the relative angle between the center lines of the two arms controls camber and to a lesser degree toe adjustment..toe is more affected by the relative position front 2 back between the two arms..both adjustments affect each other so this adjustment is best done on a laser rack..there is a ghetto way of doing the back but I hesitate to mention it.. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 10, 2006 Share Posted July 10, 2006 They dont differ. Same suspension. -Brian Quote Link to comment Share on other sites More sharing options...
