Mac Posted November 1, 2003 Share Posted November 1, 2003 The timing belts are fine, not missing any teeth or anything but the distributor isn't turning. What should I be looking for? Quote Link to comment Share on other sites More sharing options...
GLCraig Posted November 1, 2003 Share Posted November 1, 2003 the pin that holds the gear to the shaft may have sheared off. You might want to pull the distributor and give it a good inspection. Quote Link to comment Share on other sites More sharing options...
calebz Posted November 2, 2003 Share Posted November 2, 2003 Check to make sure the little screw on the back of the rotor hasn't worked its way out. Quote Link to comment Share on other sites More sharing options...
