The new ones' part number supercedes all the older GL bushings' numbers, which means that as far as the dealership is concerned, these are the right bushings.
The new bushings are in the top row in the picture, the bottom row is the old bushings. The bottom pic illustrates the difference as seen from the sides.
So, can anyone confirm that these are acceptable for use on an '86 EA82 vehicle? Monstaru said they looked like EA81 bushings, but I saw the years to which the book applied.
IF they are the right bushings, I also need to know which way they're installed.. which sides face each other on their respective sides of the strut rod plate?
This way
or that way?
Thanks guys.
WJM, if you see this, are the Super Pro Bushings available?
SPF2534K# - $TBA (approx $30~$40, these dont officially exist)
Front Strut Bar To Chassis Mount (LEADING ROD)
Kit contains 4 Bushings
To suit 18mm outside diameter shaft (Measure!)
