2000 Outback lighter wiring question
2 replies to this topic
#1 Fabric8r
Fabric8r
    New User
  • PipPip
  • 13 posts
  • Bozeman
Posted 11 July 2006 - 01:20 PM
Our 2000 Outback cigarette lighter only works when you have the ignition on. How can I change that so it has power all the time - when the key is off.
Thanks,
#2 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 11 July 2006 - 03:53 PM
easiest way would be to run a wire from the battery to the cigerette lighter, and make sure ther e is an inline fuse in that line. The multi outlet kit basically does the same thing, except for a relay that causes the outlets to be controled by the igintion switch.
nipper
#3 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 11 July 2006 - 03:54 PM
My reference shows a yellow/red wire going to F/B fuse #4. One thing you could do is remove the feed wire to the lighter socket and install another wire that goes to the fuse panel. Then put a inline fuse on the wire and tie the fused end to a hot buss source in the fuse panel.
You could also tie a fused jumper lead from the power buss to #4 fuse position. Replace the existing fuse with the jumper lead terminated with a suitable connector, that will match the fuse contact and connect it to the protected side of the fuse position. This will make the other power outlets hot at all times also if you have them.
