Snorkel Project!!!!!!!!!
20 replies to this topic
#1 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
Posted 19 July 2006 - 11:29 PM
Well I cut the hole today :-\ . It didn't come out as clean as I had hoped for. My plan is to tape off a 1/2" brder around the hole and paint it: Cheap wallyworld rubberized black undercoating, or the Outback silver??
I am not really sure which one. I am a very bad spray painter so I am leaning towards the rubberized black but I hear bad stuff about the cheap crap. This will also cover up some mishaps I had in the process. I am going to paint the inside of the fender around the hole with some rustcheck/rustoleum stuff.
Any suggestions.
Also what should I use for the pvc. I want something that wont be brittle in the winter 0deg months
Posted Image
Posted Image
:headbang: :headbang:
#2 TheSubaruJunkie
TheSubaruJunkie
    Subaru Sober since 2010 :(
  • 1,907 posts
  • Sacramento
Posted 19 July 2006 - 11:36 PM
Get some fuel line. 3/8" rubber hose, and cut a slit down the center of it. Then wrap the hole with the line, and it should give it a good look. Also, paint the surrounding area so it doesnt develop any rust. I would suggest white or silver or something to sorta match the paint.
-Brian
#3 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
Posted 19 July 2006 - 11:51 PM
Great idea. I'll find out tom. how it works. Hopefully it will cover up everything
#4 TheSubaruJunkie
TheSubaruJunkie
  • 1,907 posts
  • Sacramento
Posted 19 July 2006 - 11:55 PM
Yeah with the hose it should make your hole look alittle more round and not so jagged. Will also protect the PCV from getting all scratched up and should hold it still alittle better.
-Brian
#5 soobmater
soobmater
    Got Mud?
  • 1,668 posts
  • South Bend
Posted 20 July 2006 - 02:53 PM
:headbang: looks good man.
#6 Uberoo
Uberoo
    Subaru Wheeler
  • 2,659 posts
  • lewiston,ID
Posted 20 July 2006 - 05:23 PM
is it possible to relocate the intake to where the hole is closer to the a pillar?Just a tube from airbox to up near the windshield then punch through fender?I dunno it just kinda looks weird when theres alot of length before the a pillar.still looks sweet.paint the grey with white so it matches then the 3/8 fuel tubing arounf the hole to give it a professional touch.
#7 TheSubaruJunkie
TheSubaruJunkie
  • 1,907 posts
  • Sacramento
Posted 20 July 2006 - 05:31 PM
I think it looks badass with the PCV comming out of the front of the fender.
-Brian
#8 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
Posted 20 July 2006 - 06:24 PM
the rubber hose wont work unless I make the hole bigger (which I am not doing). It does look good though, and kodos for a great suggestion.
I'll post pics in a little bit of the snorkel completed but not painted. I still have to get a Donaldson Top Spin pre-cleaner that is going to go on the top.
I am thinking of getting some skateboard grip tape and taping off a border around the hole. See the thing is I am a very bad painter, and w/o a garage I am going to have overspray everywhere. I have tried to paint other cars in the past and it has tought me a valuable lesson: DONT PAINT
#9 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
Posted 20 July 2006 - 07:41 PM
daytime pics:
Posted Image
Posted Image
Posted Image
Posted Image
:drunk: Rum n coke and a nice clay bar and wax :headbang:
#10 scrap487
scrap487
    Certified Subaru Nut
  • 984 posts
  • Government Camp
Posted 20 July 2006 - 07:47 PM
Any suggestions.
easy, dont use pvc, use ABS, its a lot stronger and way more durable. simple test, take a piece of sch40 pcv and a peice of abs the same size, and hit them both with a hammer, the pvc will shatter and it wont do anything to the abs.
anyways, its looking really good... make sure you post pics for when you're finished :banana:
#11 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
Posted 20 July 2006 - 08:01 PM
I was planning on using just one pipe and bending it for all the bends.....well here is a pic of the piipe just trying to get the pipe at 90deg. Yea the entire 7' pipe was filled with sand.
Posted Image
#12 scrap487
scrap487
  • 984 posts
  • Government Camp
Posted 20 July 2006 - 08:14 PM
Posted Image
cool... when you're done maybe take some bondo and smooth it out before you paint it
#13 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
Posted 20 July 2006 - 08:31 PM
Well that pipe went to the disposal. I am sticking with the setup with the elbows. That took about an hour to bend like that with a heat gun in the blazing sun. That was a "just use elbows picture."
The
#14 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
The sand
#15 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
The sand was supposed to prevent kinks
#16 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
Posted 20 July 2006 - 08:34 PM
Dunno how that happened...mods can delete the 2 post that aren't complete and this one.....
#17 ryry46d9
ryry46d9
    USMB Regular
  • PipPipPip
  • 66 posts
  • pasco
Posted 20 July 2006 - 11:54 PM
:banana: i think your computer is telling you to not use the elbows and to master the heat gun action :banana:
#18 Sweet82
Sweet82
    Elite Master of the Subaru
  • 3,266 posts
  • Salt Lake City
Posted 21 July 2006 - 10:13 AM
Try applying more heat to the outside of the bend, rather than the inside?
Stretch the plastic rather than shrink it?
I'm making this up as I type....
But it seems logical!
#19 subie94
subie94
    Major Subaru Fanatic..
  • 1,577 posts
  • Hooksett
Posted 22 July 2006 - 03:37 PM
how'd you do the hook up at the air box?
and what did you use to do the cutting of the hole?
BTW-looks good
#20 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
Posted 22 July 2006 - 08:32 PM
Yea I tried this, but the pipe gets really soft when it gets that hot. Its tough and, I was kinda impatient knowing that there was a way easier way to do it in a bag, on the ground, next to me.
I just stuck it in the air box....I am going to seal it once i have it completed. I used a drill, drillign a bunch of holes in a circle. My suggestion, buy a good hole saw. I did this but I didn't have a good drill to complement it.
#21 Andyjo
Andyjo
    I'm Not Austin!
  • 1,807 posts
  • Tewksbury
Posted 23 July 2006 - 06:33 PM
if you do it really slow, you can get really nice bends... took me a good 10 minutes to heat that bend on my snorkle. have to keep it VERY even, front & back sides, all around.
