"Bellows" repair/manual steering/any suggestions
the bellows is just a dust shield i think, if fluid is coming out of it then there's likely a seal that's leaking somewhere inside of it. you said it needs sealed up, so it's leaking fluid? probably best to find a used rack or scavenge some used but good boots for it.
sorry, I did not mean to say that the rack is leaking fluid...only to seal up the rods coming out of the rack...if the rods get dirt on them and slide back and forth thru the seals, this will cause them to eventually leak/...I am trying to avoid this from happening...
