heh.. i just gunk'd my engine, and in giving it the careful look over afterwards to make sure nothing is still wet that shouldnt be (after 65+mph for about two miles, at full temp with AC on) and noticed a loose vacuum line i had seen on the pre-gunk inspection. i looked around before but couldnt find anything.. it was behind the passenger side cylinder head, just a small line coming off a larger one, with a connector still in the line.. checked it with motor running, has suction on it. looked around some more, and found it!! it went to another hose that connected to a plastic canister mounted on a bracket with a fuse, and a couple relays underneath. i cant recall what the fuse is for, but that should be enough of a pinpoint.. the vacuum appears to come thru this canister and then go across the engine bay and into the cockpit..
what is this line, and this plastic canister? plugging it in fixed a slight stumble at idle that has been annoying the daylights out of me!! i did it, and thought, check that stumble.. walked back to the muffler, and it seemed gone!! not believing it, i went and unplugged, came back in full force, so oh yeah!!
YOO-reeka, BIATCH!!!!
sorry. just an awesome feeling, because finding a leak like that usually takes me forever. this may be the first time i ever found an obvious leak like that, and actually fixed my stumble/issue at hand!
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
vacuum leaks suck worse than fusible links blow
Started by
daeron
, Aug 04 2006 08:10 AM
No replies to this topic
