Help to swap EA81 4sp and EA82 3AT between 2 Subes
P K
Hello All,
I have searched but don't have the complete detail of what I want. If someone could point me to relevent USMB threads, I would be most grateful.
Situation is I want to switch transmissions between my:
82 Brat with 4 speed D/R
92 Loyale with 3AT part-time 4WD
Desire to put the 3AT in the Brat, and the 4 speed (or get 5spd) in the Loyale. Don't condemn me for the blasphemy, I just need an AT Brat, and a DR wagon.
Unanswered questions:
1. Do I need a lift kit to get the AT under the Brat?
2. Should I ditch the 4 spd and get a 5 spd for the Loyale? (driveshaft?)
3. Will an EA81 pedal box fit to an EA82, and vice-versa?
4. Do I need to buy an EA81 torque converter or will the EA82 fit? or can I switch flywheels too?
5. What am I forgetting - I have both complete vehicles, so any part that needs to go to the other is available.
Thanks in advance, r/PK.
1. No lift needed, Brats also came with 3AT. You will need to change the radius rod plates and tranny mounts tho.
2. Yes, get a 5spd D/R for the Loyale. You will need the 2 piece driveline that comes with it.
3. Dont think the pedal boxes are the same, but might be adaptable.
4. Not sure, but I think the TC is the same. But the flexplate might be different. Easy to check tho, just slap it on and put a few bolts in. Turn the engine (by hand) and see if it rubs.
5. Dont forget the nuetral safety switchs.
