95 Impreza Mass Air Sensor Circuit Pbm.
My 95 Impreza has been stalling for about 3 weeks. It usually happens in high outside heat, warmed up, after a short time shut off. When I start the car, everything is fine for between 10 sec and 10 minutes then the engine suddenly loses all power, and the RPM's stutter. It usually takes 3-5 seconds for the engine to die completely and there is a 50-70% chance that the engine will catch in that time and I can continue driving. If it stops, I can restart right away without a problem.
After 3 weeks the car finally threw a code: 100. Mass Air Flow Sensor Circuit fault.
Is there a history on these things I should know? Any place to start looking?
I haven't had time to check the wiring yet, but I thought that is where I'd start, hoping I can find a wear point or corroded connection.
Thanks in advance everyone.
Dave
