drive shaft vibration???
3 replies to this topic
#1 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 13 August 2006 - 03:52 PM
my rear diff pinion seal is leaking and i was going to replace it. but when i got to the pinion nut, i couldn't break it lose. not enough room under the car to swing the breaker bar. so i put it back together and decided to take it to the shop to be fixed.
well, after i got it back togehter, i now have a slight vibration in drive line (feels like the rear) when i take off from a stop. start rolling, slight vibration (half second) then it smooths out and runs fine. 97 obw 115k miles.
my first guess was the support bearing, maybe it's not tight, but i have no experience with anything like this so i don't know. any thoughts? i guess i should try the FWD fuse to see if that makes a differeence.
thanks , john
#2 Manarius
Manarius
    1995 Subaru SVX LSi
  • 1,609 posts
  • Grantham
Posted 13 August 2006 - 07:11 PM
One of the U-Joints on the shaft might be shot - that could cause the vibration.
#3 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 13 August 2006 - 08:05 PM
Its a u joint in the center of the car most likely. Het under there and shake the driveshaft, there shold be no play in the u joints or bearing. It will get worse with time and make the car undriveable. Go to a junk yard OR a driveshaft shop and let them rebuild it. Dont go to subaru as its not worth the 400.00 + procetag.
nipper
#4 johnceggleston
johnceggleston
  • 6,712 posts
  • Virginia
Posted 14 August 2006 - 08:49 AM
thanks, i'll try a used one. is there any chance i installed it wrong and caused the problem,?? i would hate to do it again with another part.
john
nipper
