Legacy Strut Lift Question
5 replies to this topic
#1 MSSLGECKO
MSSLGECKO
    Certified Subaru Nut
  • 755 posts
  • Missoula
Posted 13 August 2006 - 09:54 PM
Is your front camber effected by the use of outback or forester struts? How is the axle extension?
This recent post made me think about it...
#2 ezapar
ezapar
    [OTD]
  • Moderator
  • 27,355 posts
  • Seattle
Posted 13 August 2006 - 10:27 PM
Yes, it is affected. But. There is a camber adjustment. The upper of the two bolts on the bottom of the struts. Just dial them all of the way out, mine turned out fine. I haven't noticed any unusual wear on the outside of my tires since. I did it over a year ago.
This is only on the front.
#3 strat
strat
    USMB is life!
  • 131 posts
  • Williamsport
Posted 19 August 2006 - 03:24 PM
you could also get the outback cradle spacers that would allow everything to go back into factory spec.
#4 sayn3ver
sayn3ver
    Eat, Live, Breath Subaru
  • 255 posts
  • South Jersey
Posted 19 August 2006 - 05:12 PM
my rear camber is pretty faacked(on my impreza using outback struts).
But i havent tried to get it aligned yet(i dont know how to do the rear). the fronts can come pretty close.
#5 Andyjo
Andyjo
    I'm Not Austin!
  • 1,808 posts
  • Windham NH
Posted 19 August 2006 - 09:58 PM
In the rear, your camber adjustment is on the controling arm type thing, in towards the rear diff.
#6 soloracer34
soloracer34
    USMB Regular
  • PipPipPip
  • 37 posts
  • Parker
Posted 19 August 2006 - 10:46 PM
I just completed mine today. I put 98 Outback KYB GR-2 struts on my 90 Legacy LS Wagon. I kept the original springs and strut tops. Measuring before and after as well as the parts I got 1.25" lift in the front and 1.75" in the rear. It looks pretty level as it was a bit saggy butt before. I had to crank the camber adjust bolts all the way in in the front to dial out positive camber, aftermarket camber bolts would help get it back into spec. I would guess right now I've got close to zero camber in the rear and about .5 degrees positive on front. Measuring things after the swap I have 12" clearance to the bottom of the bumper lip and just shy of 10" to the bottom of the oil pan. The axles are at a much higher angle than stock of course but do not appear to be excessive. Subframe spacers would give a bit better axle angle and down travel but I think the additional axle stress is minimal.
So far I give it two big thumbs up.
