Auto Transmission Slipping
9 replies to this topic
#1 Pooparu
Pooparu
    way too obsessed
  • 1,371 posts
  • Portland, Oregon
Posted 15 August 2006 - 01:50 PM
I have a 1994 Impreza with an automatic transmission and I'm having a problem with the transmission slipping. Prior to the problem I had a fluid leak and every time it got low it would slip so I would fill it up and it would work fine. Well I was headed up to the mountains and it started to slip again so I pulled over and filled up the transmission again, but this time it just kept slipping. So is it a problem with the transmission itself or the torque converter?
#2 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 15 August 2006 - 05:57 PM
Well slipping is never good for an AT as it burns/wears out that valuable clutch material. Does the fluid that's in there smell burned or lock discolored? How did you check the fluid level? If you're a bit low or whatever, it might become more slippy at steep grades as the fluid sloshes more to the front or back of the AT. Where was it leaking from? What kind of ATF are you putting in there?
#3 Pooparu
Pooparu
    way too obsessed
  • 1,371 posts
  • Portland, Oregon
Posted 15 August 2006 - 06:01 PM
I'm putting red line fluid in. It looks like it's leaking from the rear main. The fluid looks and smells fine too.
#4 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 15 August 2006 - 06:09 PM
Cool. Which Red Line ATF are you using and how many total quarts do you think you've put in over the lifetime of the unit?
#5 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 15 August 2006 - 08:24 PM
Odds are you fried the tranny. If the fluid got low enough so that the clutches could not fully engage, it also got low enough that it could not cool or lubricate the surfaces of the clutchs. These are wet clutches and quickly wipe out if they go low on fluid.
nipper
#6 ericem
ericem
    First Gen Legacy Master
  • 2,477 posts
  • CANADA Maple,ON
Posted 15 August 2006 - 09:20 PM
nipper
Always giving the bad new eh?
#7 nipper
nipper
  • 18,195 posts
  • Long Island NY
Posted 15 August 2006 - 09:28 PM
grrrrrr seems like that :(
i'm sorry
should have maybe said think of all the gas youll save while the car waits for a tranny?
nipper
#8 Pooparu
Pooparu
    way too obsessed
  • 1,371 posts
  • Portland, Oregon
Posted 16 August 2006 - 10:56 AM
Dose anyone know where I could find a cheap transmission for my rig?:confused:
#9 2X2KOB
2X2KOB
    Subaru Fanatic!
  • 393 posts
  • Midstate MO
Posted 16 August 2006 - 11:29 AM
First choice would be your local you-wrench-it junkyard, if that fails try www.car-part.com or equivalent.
Good luck
(and there's nothing wrong with telling the truth)
#10 Eljefe
Eljefe
    USMB Regular
  • PipPipPip
  • 70 posts
  • Tucson
Posted 17 August 2006 - 02:21 PM
You can't use the word "Cheap" and Transmission in the same sentence. I just had my tranny overhauled and spent more that the car is worth (on the market) I really like my Legacy wagon so I don't mind spendintg the $$. You can spend the money and have all new parts, or you can go to a salvage yard and maybe get a good used tranny or maybe get the same thing you have now.
