Subaru 2000 Outback---error code P1133
10 replies to this topic
#1 bentonjim
bentonjim
    New User
  • Pip
  • 1 posts
  • Jefferson City, MO
Posted 27 August 2006 - 08:53 AM
I have a 2000 Subaru Outback (purchased it new), automatic transmission and now have 96,000 miles on it. Recently the CHECK ENGINE light comes on and stays on even though the car runs fine and is getting normal gas milage. I purchased an Equus code reader and it indicates an error code of P1133. This particular error code is not listed in the official Subaru manual for this particular year equpped with automatic transmission. It does list P1131 and P1134 codes and mentions they are associated with front and rear oxygen sensors. If anyone has any additional info on this error code P1133 I would certainly appreciate more information. You can email me direct if desired: bentonjim@aol.com
JIM in MISSOURI
#2 BigMattyD
BigMattyD
    Subaru Fanatic!
  • 405 posts
  • Syracuse, NY
Posted 28 August 2006 - 07:58 PM
here is a diagnostic chart for p1133 from your year vehicle.
matt
#3 sea#3
sea#3
    Subaru Fanatic!
  • 354 posts
  • Vancouver Canada
Posted 28 August 2006 - 09:07 PM
Check with the dealer there may be an oustanding recall on the front (A/F) sensor
Get your VIN # and phone it in and see
SEA#3
#4 cannonball
cannonball
    User Awaiting Email Confirmation
  • 205 posts
  • Greenville
Posted 29 August 2006 - 09:22 AM
I notice in the attached file that it says to shake the wiring harness and monitor the voltage to see if it moves more than 8 volts. Why would shaking the harness have anything to do with voltage unless Subaru is saying that the harness could be faulty(shorted)? Am I reading that correctly?
#5 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 29 August 2006 - 11:25 AM
It's not necessarily that the harness is shorting pins, it's probably more likely to fail open, or if there's any corrosion in there it will exhibit more resistance than is ideal.
P1133 is in the OE manual for '00OBW; it says DTC P1133 - FRONT OXYGEN (A/F) SENSOR HEATER CIRCUIT HIGH INPUT. (sorry about the caps-cut&paste).
As already mentioned there was a recall on the front o2 sensors where they'll replace it for free (some piece can break off or something I think); so if it hasn't been done yet and your vehicle was included might as well get it done.
#6 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 29 August 2006 - 11:28 AM
But if it's not free I think my front sensor was about $60 and it is not that hard to change. My first move would be to change it because it is a consumeable and and a 2000 model should be about done anyway.
#7 Richard1296
Richard1296
    USMB Regular
  • PipPipPip
  • 109 posts
  • L
Posted 19 November 2006 - 09:55 AM
Is the info the same for auto transmission as for manual.
I would expect so but I hate to troubleshoot and then find
there was a difference.
or could you post it for an auto'
thanks
Richard
#8 afeinstein
afeinstein
    New User
  • Pip
  • 1 posts
  • Cleveland
Posted 10 October 2011 - 01:16 PM
Seems the use of a fuel-air ratio sensor is specific for the MT Legacy.
I had this same code P1133 and the OBDII said however (LOW) below and I was able to clear the code by replacing the sensor. Used a Denso 234-9018. Do not buy a UNIVERSAL O2 sensor. It will NOT work!! Needs to be OEM on this car. Believe me I tried it. The OE unit made by Denso can be bought at auto parts stores and is the same as the dealer OE part. 3x check that they sell you the right unit for a MT Legacy which is not the same at the AT one.
It seems the diagnostics pathway attached above is just for a high condition.
My Legacy had 115k, started to smell a little rich, and then on cold mornings, idle RPM would be very high for a few minutes and then when the car warmed was fine. Seems that both the sensor heater was messed up as well as the actual o2 sensor part.
The sensor came out easily despite the awkard angle.
I spend hours on mind so wanted to at least share my experiences.
#9 ocei77
ocei77
    Eat, Live, Breath Subaru
  • 872 posts
  • Monticello,NY
Posted 10 October 2011 - 04:22 PM
Bosch( the originators of O2 sensors) will also work with no problems.
Let the car idle a few minutes and hold the bung with an open end wrench, then turn sensor.
O.
#10 Crashbox
Crashbox
    New User
  • Pip
  • 1 posts
  • Petaluma, ca
Posted 09 June 2012 - 11:29 PM
One of the things I'm in the habit of doing when diagnosing an o2 heater fault, or any heater related fault, is ohm test the heater in the o2. Open or shorted heaters are common, and computers can set a variety of heater circuit codes.
Tom
#11 glennb
glennb
    Newbie
  • Pip
  • 1 posts
  • Massachusetts
Posted 12 February 2016 - 11:47 AM
This statement below is correct. If you have the MT (manual transmission) version of the subaru outback you have the dual inline cats.
You must replace the front sensor with a factory OEM to get everything working right. Be prepared to pay $150 to $180 for it.
That said the rear is just a plain oxygen sensor and an oem good equivalent will work.
