P0446-Evap Emmis Control System
The error code P0446 is a code showing an electrical problem with the circuit to that valve. You stated you saw 14 volts getting to the coil of the solenoid and if I understand correctly you saw 26 ohms for the coil resistance which should be correct I think. If these things are correct then there must be a bad connection to the coil somehow.
  • 2 months later...
  • Replies 77
  • Created
  • Last Reply
Top Posters In This Topic
  • 3 years later...
I know it's been quite awhile but I wanted to finish off my P0446 code experience. After checking & cleaning, or replacing, many of the parts and areas advised to, it ended up being a serverly corroded wire connection to the O2 sensor!! Cleaned it all up and it has been running without the light coming on for months.
