Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
P1443 Evaporative emission control system vent control function problem???
#1
Posted 03 September 2006 - 08:10 AM
What is the deal with the evaporative emission control system? What is that? Does it suggest an exact part(s) that should be replaced? Is it a cause of misfires, or is it affected by the misfires?
My car has new OEM plugs, new OEM wires, I've cleaned the fuel system and the throttle body with seafoam.
Any info is appreciated. I'm open to checking stuff with my ohmmeter.
Thanks,
Ian
#2
Posted 03 September 2006 - 10:21 AM
Please update us on what you do/find! I will do the same.
Good luck!
Mike V
#3
Posted 03 September 2006 - 11:59 AM
Once again, pls detach and save this as I'm now at my attachment limit.
#4
Posted 10 September 2006 - 06:16 PM
I ran a can of seafoam through my gas tank, drove the tank empty, then cleared the CEL codes.
I've driven 300 miles since the codes were cleared, with no CEL.
The guy at Autozone who cleared my code said that an open gas cap can cause P1443. Obviously, I have read the plethora of posts about the gas cap setting off the CEL, but I don't rememebr reading that it caused a P1443 code. The Autozone guy suggested that it did. I doubt that I failed to secure the cap at any point, but whatever.
Anyway, maybe the can of seafoam cleared out some thing in the fuel system that was throwing that code. One thing's for sure... the engine feels a lot smoother and I don't smell as much "gas smell" in the exhaust when I first start up the car. All good things.
I guess the moral of the story is... seafoam the crap outta yo rig... before you do anything else.
#5
Posted 10 November 2009 - 08:22 PM
I just bought a '99 Outback Limited with 63,000 miles, a clean creampuff. It runs just fine, but when the tank is down nearly 1/2, it starts throwing the same code. When it's full, no codes. I replaced the gas cap, but it didn't work, obviously, or I wouldn't be chiming in now.
Before I start looking at purge valves, do you guys think the Sea Foam fuel treatment idea will help? Any ideas will be appreciated.
#6
Posted 10 November 2009 - 09:41 PM
Seems kinda strange that it does it only when its under a half tank. Have you tried keeping it above a half tank for a few weeks to see if it stays away? (or is that how you figured out that it only comes on under a half tank :-\)
edited for content which isn't allowed by the blocker. Muh bad. :-P
#7
Posted 11 November 2009 - 12:42 PM
I just filled up yesterday and put a can of Sea Foam in. We'll try that first. Like you said, it cannot hurt.
I would like to get a manual for this car. I have ones for my other vehicles. If anyone knows where I can get a good one reasonably priced, let me know. I'd prefer it not be a Haynes. I have one for my Jeeps and I've found errors.
#8
Posted 11 November 2009 - 01:25 PM
How far do you generally drive each day?
Edited by Fairtax4me, 11 November 2009 - 01:30 PM.
#9
Posted 11 November 2009 - 05:46 PM
I'll take your advice on getting a manual. Thanks.
#10
Posted 11 November 2009 - 09:48 PM
#11
Posted 11 November 2009 - 10:53 PM
I generally put about 90 miles on a day.....give or take a few.
Reason I asked was because most Evap codes are two trips faults. Meaning that the fault has to occur on two separate "trip drive cycles" or trips in a row before it will set the CEL.
If you make a couple of short drives each day the ECU may not have time to finish the checks that constitute a "drive cycle" for that system. What a drive cycle consists of changes for each monitoring system in the car. So a simple 5 minute drive may be enough for one system. But for another system there may be numerous conditions that need to be met in order for the cycle to be considered "complete".
Plug in the two green connectors under the dash as suggested, and see if the vent control solenoid clicks when it is engaged. It should be accessible under the car near the fuel tank.
Edited by Fairtax4me, 11 November 2009 - 10:57 PM.
#12
Posted 13 March 2013 - 09:21 PM
I pulled P1443 out of my 99 OBW man. Also pulled misfire codes out for 3 cylinders. I've pulled misfire codes before, but I never actually feel the misfires when the CEL is flashing.
Thanks,
Ian
gas tank vent valve or solenoid valve stuck.
#13
Posted 14 March 2013 - 10:01 AM
Guess you missed the part where the post was from 2009!
O.
