Hi all,
Can you replace the duty solenoid c without removing the tranny tail housing? I am getting a code 24 with is the solenoid. Tomorrow I am going to get under the car & check the solenoid. I would like to know so I can buy the gasket while at the dealer getting the solenoid. Thanks.
Josh,
Bad torque bind. Installing the fuse helps a little but when I check the duty solenoid I get a open. From what I can find that will put the AWD into 50/50 regardless of the fuse. I have already checked tires & changed all the fluids. Anything I might have overlooked? Thanks.
