Pinouts for 84 Turbo instrument clusters
6 replies to this topic
#1 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 19 September 2006 - 11:34 PM
I have the 83 Factory Turbo Supplement and 83 FSM as well as the 84 full factory manual and besides a half page indicating what pins are different for Turbo models theres really not a whole lot to help me convert a failed digital to a analog cluster setup.
Has anybody ever done the swap successfully?
Ill also point out:
When the digi dash fails it emits a very loud screeching noise from the dashboard. Removing the Turn/4wd AT fuse makes the noise shut off but of course you lose the turn signals and I believe you lose the power windows. In a pinch in decent weather you can keep your sanity and just use hand signals to get home.
As I work thru the pinouts I will note them as best I can for future. Ill also scan the pages from the FSM with the Analog pinouts that seem to be there but incomplete/wrong at times.
Any help is appreciated!
Gauges/indicatiors On digital:
Oil Light
Temp in bars
Digital Speedometer
Turbo spool light
Charge Light
AT OIL temp light
Digital Tachometer
Gauges/indicators on analog
Oil light-SAME shouldnt be hard
Temp gauge
Speedo-direct plug and play (DONE)
Turbo meter
Volt Meter
AT/Oil temp light-Same shouldnt be hard
Analog Tach-signal wire from coil, easy.
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,922 posts
  • Portland
Posted 19 September 2006 - 11:43 PM
Shouldn't the only differences be the 4WD and Turbo indicators between the Turbo and Non-Turbo Digi's?
I'll see if I can find my notes on this. I put an 80 cluster in mine.... it's probably got slight differences. A lot of it should be the same tho. I had the biggest problems with the door ajar/dome light setup. All my ajar lights work, but the dome light does not come on when you open the rear drivers door :confused:. I called it good enough and quit screwing with it.
I'll help with what I can.....
#3 ShawnW
ShawnW
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 19 September 2006 - 11:47 PM
Im goin turbo to turbo so I hope its fairly easy but I know better. :)
#4 GeneralDisorder
GeneralDisorder
  • 21,922 posts
  • Portland
Posted 20 September 2006 - 12:18 AM
I had problems with differences in some circuits not having diodes in them on the 80 cluster, but the digital did. I had to add the needed diodes into the circuit before it entered the cluster. But this may not be needed on an 83/84 cluster. Just be aware of differences like that, and look for them on the schematics. Took me weeks to figure that out.....
#5 LUVMYBRAT
LUVMYBRAT
    Subaru Nut
  • 589 posts
  • Laramie
Posted 20 September 2006 - 06:14 PM
do you already have an anolog dash?
#6 ShawnW
ShawnW
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 22 September 2006 - 12:05 AM
Yep. Already have it.
#7 LUVMYBRAT
LUVMYBRAT
    Subaru Nut
  • 589 posts
  • Laramie
Posted 22 September 2006 - 08:25 AM
cool, I was gonna tell ya I just knocked my t-brat in the head and it was a anolog dash.
