Brake Pedal Creaking
7 replies to this topic
#1 Guest_Exocet_*
Guest_Exocet_*
  • Guests
Posted 04 August 2003 - 07:37 PM
The brake pedal on my 94 Legacy wagon is starting to make a creaking noise when applying the brakes. It sounds as if it is coming from around the firewall. It sounds like a lack of lubrication somewhere. I lubed the pivot points on the pedal, but it is still there. Could it be the vacuum booster?
#2 Guest_Setright_*
Guest_Setright_*
  • Guests
Posted 05 August 2003 - 11:46 PM
Most unlikely that it is coming from inside the booster, but nothing is impossible.
Maybe there is a joint you missed? Perhaps the bolts holding the booster need tightening?
#3 terryb52
terryb52
    USMB Regular
  • 132 posts
  • illinois
Posted 18 August 2003 - 07:21 PM
I have the same problem with my '92 Legacy. How did you go about lubricating it???
#4 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 19 August 2003 - 12:22 AM
I like to use a "dry" oil for such things, you know the sort that leaves a wax film on components. "Wet" oils will always run and find thier way into places they shouldn't be - like on the brake pedal rubber!!
#5 terryb52
terryb52
    USMB Regular
  • 132 posts
  • illinois
Posted 19 August 2003 - 01:15 PM
What is the brand on that? Do I just squirt it down the pedal shaft from the floorboard???
#6 Lesbaru
Lesbaru
    Gir is my copilot
  • 681 posts
  • Seattle
Posted 21 August 2003 - 10:59 PM
My clutch pedal does the same thing. How do I make it stop?
#7 Setright
Setright
  • 3,176 posts
  • Denmark
Posted 22 August 2003 - 12:13 AM
Well, there's a company that makes stuff for bikes: "Finish Line"
I believe their dry oil is called "Krytech" - but just ask for it in any mountainbike shop...and hopefully they'll have it or something similar ;)
It can be a royal pain in the backside to apply in the under dash hinges, ideally, remove the driver seat (only five bolts) so you have room to get upside down!
#8 Tiny Clark
Tiny Clark
    Certified Subaru Nut
  • 807 posts
  • Germany
Posted 22 August 2003 - 01:14 AM
A couple drops of brake fluid on the rubber/steel mating surfaces will usually stop those noises.
