Help with my list, I'm taking my car into the shop
12 replies to this topic
#1 JaySmurff
JaySmurff
    New User
  • PipPip
  • 12 posts
  • Lebanon
Posted 25 September 2006 - 08:05 PM
I'm talking to the auto shop and here is what I'm considering. My car is a 97 Impreza w/ 79k miles.
- Oil Change + New Oil Filter
- Alightnment/Rotation
- New Timing Belt
- New Water Pump
- Replace Cam + Crank Seals
- Reseal Oil Pump
Is any of this overkill? And am I missing anything? Because I don't want to change anything I don't need to. However I don't want to leave something out and have to end up taking it right back in if I have a problem. Thanks!
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 25 September 2006 - 08:35 PM
What you have on there looks about right. Only thing you may want to do some time in the future is replace the struts. They start to head south around 80k or so.
#3 Sube dude
Sube dude
    New User
  • PipPip
  • 20 posts
  • Western Canada
Posted 25 September 2006 - 08:41 PM
- New Timing Belt
- New Water Pump
- Reseal Oil Pump
Are the cam (timing) belts original? They're overdue if they are. I think 60k mi. is what's suggested. What about the ALT/PSP/AC belt? The fuel filter might be long in the tooth. I'm not sure why you'd change the WP but you may want to change the coolant if it's getting old - the inhibitors may be used up. Not a good thing in an aluminum engine. HTH. Cheers.
#4 Mark-O-Back
Mark-O-Back
    USMB Regular
  • PipPipPip
  • 60 posts
  • Ravensdale, WA - USA
Posted 25 September 2006 - 08:49 PM
IF you haven't addressed these already... or don't know as this is a 10 or 11 year young car consider these for your list.
Brake fluid flush & check the pad wear.
Tranny fluid.
Spark plugs.
Air filter? Gas filter? (or DIY)
Replace drive belts, you know alternator A/C belts. Keep the old for spares.
The new water pump will renew the antifreeze for you, how are the associated hoses? Thermostat. Good time to renew these too.
Cha Ching! Boat payment, maybe but peace of mind
:burnout:
#5 JaySmurff
JaySmurff
    New User
  • PipPip
  • 12 posts
  • Lebanon
Posted 25 September 2006 - 08:50 PM
Yes its original timing. A lot of people are on the fence about the WP/TB issue... Some say change it with timing belt, others say I could wait till say 150k miles, so i really dont know.
#6 avk
avk
    Certified Subaru Nut
  • 965 posts
  • Somerset County, NJ
Posted 25 September 2006 - 09:05 PM
I did a timing belt service at just over 80000 miles and here's some other things from my list:
-replaced two O-rings between cylinder heads and camshaft supports. Same part number, both were leaking. Replaced O-rings between dipistick tube and oil pan (also a pair) because the tube had to come off to reach the cam support on the left.
-replaced crankshaft pulley because rubber layer had cracks. Don't know if it was an overkill or how common those cracks are. Used new bolt and key for a good measure, they were about $5 together.
-replaced all belt rollers and the tensioner because new ones had to be on hand anyway as I didn't know what I'd find. If I was doing it at 60000 miles like it was supposed to, I wouldn't have bought those parts. If your shop has parts in stock they would replace only what's necessary, in any case.
-replaced timing cover gaskets but the old ones were usable even though the one on the bottom center was slightly distorted because of oil leak from the seals. That gasket is likely the only one that ever needs to be replaced.
-Since my choice was to remove the radiator, new hoses and thermostat were put on, also the radiator cap, and the exposed AC condenser was cleaned.
-Don't forget the heater bypass hose at water pump.
#7 dmanaenk
dmanaenk
    Eat, Live, Breath Subaru
  • 312 posts
  • AA
Posted 25 September 2006 - 09:08 PM
If you are one of those who like to be on the safe side - inspect/replace all the pulleys/rollers/tensioner with the TB job
#8 tforce
tforce
    USMB Regular
  • PipPipPip
  • 91 posts
  • White Pass
Posted 25 September 2006 - 09:13 PM
I would change the WP and termostat for sure. The last thing you wanna do after all this work is have something go wrong, overheat the thing and blow your head gaskets. Make sure you use a Subaru thermo....the aftermarket ones you get at auto parts stores are weak and will fail. If you have any significant oil leaks then it wouldn't hurt to check/replace your front main and valve cover gaskets too.
#9 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 25 September 2006 - 09:26 PM
Couldnt agree more and its 9 years old. People that recommend not doing the water pump (say to do it every other time you do a timing belt) would say that you should average 15K a year and need it swapped every 4 years or so. Coolant should be changed every other year MINIMUM on a Subaru and if it hasnt been the corrosion on the WP bearing would be enough to warrant replacement as well.
#10 Mark-O-Back
Mark-O-Back
    USMB Regular
  • PipPipPip
  • 60 posts
Posted 25 September 2006 - 09:49 PM
Couldnt agree more and its 9 years old. ...
OK 9 or 10 YY, my 97 recently had it's 10th as it was made in late 96
(Usein' my fingers ahh let's see, Late 96, 97, 1, 98, 2, 99, 3, 100, Dang! stupid numbers! :D)
Yes what ShawnW said.
#11 fnlyfnd
fnlyfnd
    Subaru Nut
  • 748 posts
  • Buffalo, NY
Posted 25 September 2006 - 10:03 PM
Most of this has been covered, but heres my list i just ordered today from Jamie:
Flywheel
clutch cable
timing belt and tensioner
thermo
water pump
w/p gasket
cam seals
front and rear main seal
valve cover gaskets/grommets/spar plug seat
Oil seperator plate
oil pump o-ring
oil filter
Other thing I have or will be getting soon:
new gear oil
new motor oil
new serpintine belts (gatorback)
clutch kit
#12 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 26 September 2006 - 12:05 AM
Well look at it this way, it adds only the cost of a water pump to the bill, as oposed to later on replacing the waterpump and the labor to get to it. Its just cheap insurance.
nipper
#13 JaySmurff
JaySmurff
    New User
  • PipPip
  • 12 posts
  • Lebanon
Posted 26 September 2006 - 07:23 PM
nipper
Yeah I'm taking it in friday and decided I'm doing the waterpump. I mean its 10 years old anyways, why not? ;)
